check valve
  • Shawnb
    • Jun 2008
    • 88
    check valve
    is their a check valve inside breather crankcase, that keeps oil in and lets air out if so where can i get one. talk to a 30 year motorcycle mechanic and he said ther was is there one on this bike? And. How hard is it to find and change engine piston bearings? any help would be useful
    • 8798
    breather
    No, there isn't a check valve on these engines. If you are getting excessive oil in the airbox, you're rings are probably bad. You could install one of these.
    Parts are still available(conrod bearings), but you must remove engine and split the cases in order to replace them.
    • Shawnb
      • Jun 2008
      • 88
      check valve
      thanks but at high rpm,s this bike actually shoots a large stream of oil and fuel which has mixed out of the breather case tube it probably squirts about 5 to 7 feet.
      • randy
        • Dec 2003
        • 4521
        Shawnb,
        Have you overfilled the crankcase? Check oil level with the bike on the center stand, not on the side stand.
        • Shawnb
          • Jun 2008
          • 88
          check valve
          changing oil and filter some time this weekend seems to be a lot more than 4 quarts in bike almost two quarts came out when i took the oil filter off still a lot of oil left in bike will find out if that is the problem i sure hope so.
          • Shawnb
            • Jun 2008
            • 88
            check valve
            yeah i hope i got about 2 quarts out when i took off the oil filter and there is more than two quart still left in it hopefully thats the problem i don't think it is the rings.
            • blue giant
              • Aug 2007
              • 880
              • Ontario, Canada
              Shaun is it possible that there is gas in the oil? If your carb needle and seats are leaking it might explain the extra amount in the engine.
              Just a thought.
              Paul
              Paul
              1983 XJ1100 Maxim
              1979 XS1100 Standard
              1980 XS1100 Special
              I'm not a motorcycle mechanic but I play one on the internet.
              • mitch
                • Oct 2002
                • 934
                • fredericton new brunswick canada
                Gas in oil ?
                Take a stick put it in the oil then see if it will light if it lights right up theres gas in your oil . then you need to do the carbs or the shutoffs
                Doug
                Doug Mitchell
                82 XJ1100 sold
                2007 Stratoliner 1900 sold
