How many gallons to fill up 78E
  • Korr
    • Jul 2008
    • 293
    • Torrance, CA
    Hi guys I've seen alot of specs on our 1978E's & they all say that the gas tank can hold 5.5 gallons. I notice that even after running through half of my reserve(specs say 1 gallon reserve) i can only put in 3.9 gallons to the neck with bike the sitting straight up. Anybody with a 1978E able to verify how much gas we are able to pump if the tank was completely empty? Thanks guys
    1978 XS1100E Standard
    Tkat Fork Brace
    On Hold
    TopCat S.O.F.A. + Fuse Block
    Mike's XS Pod FIlters
    Hey Korr,
    I hate to ask, but are you sure it has the Standard Tank??
    BTW, specs say 5.3 US gallons.
    The capacity you are describing sounds more like the special?
    I can't remember seeing any photos of your machine. The standard has those knee indents, the special is the teardrop.
    JAT!?
      • 5055
      The only way to know for sure is to take a gas can with you and intentionally run the tank dry, and close to a station.
      • blue giant
        • Aug 2007
        • 880
        • Ontario, Canada
        No Special in 78!
        Should be a Standard!
        Does it have the original tank?
        Paul
        1983 XJ1100 Maxim
        1979 XS1100 Standard
        1980 XS1100 Special
        I'm not a motorcycle mechanic but I play one on the internet.
          • 7657
          Korr,
          I know you are close to my location. Send me a pm, and I can help out. I am "looking for work" once again, so I am free weekday's. I can probably ride over the hill and meet you for lunch at or near your work local. I will then be able to know what is going on with your bike.
          I DID just put 4.7 gallons into an almost empty '79 Standard tank today. This should be the SAME tank you have on your bike. My thought is someone put a few dents in the tank, and just put bondo over them, instead of trying to pull them out.
          • Korr
            • Jul 2008
            • 293
            • Torrance, CA
            Yes it's a standard. It is definately not shaped like a teardrop. Could somebody post a link to the "how to post a picture" thread thnx I'm free on friday i'll pm yah and i'll cover for lunch
            Tkat Fork Brace
            On Hold
              • 7657
              Korr,
              I'm in a "class" Thursday and Friday next to the San Jose Airport. I WILL have an hour off for lunch, so I can still help out. Let me know if this is OK with you, as I do not know what part of the bay area you are in. PM me and I'll give you my cell number, or send me yours. We can then try and hook up, so I can take a look at you machine.
                • 2058
                Korr-register with Photo bucket(its free)Take a picture if you have a digital camera-Does your laptop or desktop have a place where you can take the memory card and put it in? If it does then send it to your my documents folder.Once you have done that,log in to your Photo bucket account and upload the photo from your my documents folder.It should take maybe 10 seconds.Once you have done that,at the bottom of the photo should be some words.The very last line,highlight it and hit Ctr l C =copy.Then when you post at the end of the post hit Ctr l V =paste and then hit submit reply.Your photo should appear.
                • planedick
                  • Mar 2005
                  • 2068
                  • Yorba Linda, California
                  5 gal
                  I have put 5 gal in mine. I have a trick though. I cut a peice of Schedule 40 black ABS pipe to 5" long and it will fit rather tightly over the fill spout so I don't have to hold the rubber thing back when I fill up. Additionally, when on the road and going to get right back on and ride, I can fill up inside the tube several times and it will slowly bubble down and fill the tank much higher than normal. I have filled up this way on trips which give me a much longer range. Normally I have to stop for fuel at 140 miles, but when I fill this way I can go 175 miles and reserve is at 140 instead of 110.
                  Drilled airbox
                  Tkat fork brace
                  Hardly mufflers
                  late model carbs
                  Newer style fuses
                  Oil pressure guage
                  Custom security system
                  Stainless braid brake lines
                  • gnevelesx08
                    • Apr 2005
                    • 107
                    • Whidbey Island, Washington State
                    1978E Fuel Tank Capacity
                    Okay, I have the 1980G. I don't know fuel capacity for mine either, but the Specifications to the left on this page indicate:
                    Cycle magazine January 1978 says 4.2 plus 1.0 gal reserve Total 5.2 gals.
                    Cycle Guide Magazine January 1978 says 5.8 gals including 1.3 gals reserve.
                    I know it don't help, but thats what the specification page says.
                    Don't forget you have fuel in the carb bowls, fuel lines, and inline filters if you got them. It all adds up especially with the price of gas these days
                    80XS1100G (Ebaybe) Whidbey Island, WA
                    Lightning of 4 is better than thunder of 2.
                    I always wanted a Harley. Not anymore! XS11 rules!
                    • Korr
                      • Jul 2008
                      • 293
                      • Torrance, CA
                      here;s the picture and all those stains on the ground are not from any of my vehicles
                      thanks for the help on uploading pictures guys
                      Tkat Fork Brace
                      On Hold
                      • GARTHXS
                        • Nov 2007
                        • 1631
                        • Seattle
                        finally a picture
                        I'v been wonderin what your bike looks like , lets get a better shot of that fairing?
                        91 kwaka kz1000p
                        Stock
                        ( Insert clever quote here )
                        • strom
                          • 1577
                          • Slovenia, EU
                          Looks nice...
                          Alltho: 78 was only in macho maroon methinks... this looks like blue to me. Since it still has the stripes I assume its prolly an original color alltho I dont remember it.
                          Seat is from a H or something... euro 1.1 standard had such a seat - slightly lower in front than 78/79.
                          Not sure bout the engine... but I think only euro models had black engines. You definetly still have the kickstarter, but the clutch cover doesnt convince me. Mine have some fins on them.
                          Heres a pic of my 78 with 79 (model year was prolly 80, 1.1 eu standard in any case) seat/gas tank/side panels:
                          And the 78 with its stock stuff... eu models had XS 1100 on the sidepanels, but due to the kindness of our member here I got XS Eleven reproduction badges. I wont say who it was so you wont swamp him with requests
                          Anyway, this bike atm is in need of some mufflers, gearbox work etc... but has vetter fairing and cases on No real idea what to do with it since I really dont have the time to work on it.
                          • Korr
                            • Jul 2008
                            • 293
                            • Torrance, CA
                            I actually cut out alot of the seat foam to put that indentation there. My side panels say XS eleven just like your second picture. So my bike could've been a euro model?
                            Tkat Fork Brace
                            On Hold
                            • switz1
                              • Feb 2007
                              • 70
                              • Bushnell, IL.
                              Nice
                              Them there are some very nice rides, bothya!
                              1978 1100E Standard
                              2 1985 700 Maxim's (black & red)
                              1986 600 Radian (basket case)
                              1979? GS1000 (no title)
                              1980 1100SG Special
