Scared
  • schpiff
    • Mar 2003
    • 175
    • south central Wis
    Scared
    I just looked at parts-n-more for a rebuild for a 81 special..It includes a "rubber plug"...almost got my carbs workin good... now I see a piece I cannot figure where it goes...but its included...EEK...
    '81 sh " Maime" The Nature of The Beast
    Rubber Plug
    Hey there Schpiff,
    Perhaps it's the plug that covers the synch tube on the intake port, or over the inlet port on the carb itself, since #2 has one for the Vacuum advance hose?
      The rubber plugs may be meant to go in on top of the pilot screws to keep dirt and bugs out. If so, you can use them or lose them.
      • Bill__Woods
        • 281
        • Circleville, Ohio
        Hello,
        The parts microfiches for the 81 sh does not apply to all models.
        My 81 SH has uncovered pilot jets. As it feeds from the bowl.
        pilot jets that take the rubber plug feel from the mail jet.
        If you install the rubber plug on the wrong kind, the circuit starves for fuel, or draws too much.
        To determine if you need the plug, look for a small hole going from the main jet to the pilot. If there is a hole there, they need the plugs. No hole, no plug.
        I have 2 sets of carbs:
        the original 81 SH set - Uncovered pilot jets
        set of 80 SG carbs - Unvocovered pilot jets also
        You probably do not need the rubber plugs on your bike, as they are not applicable to your carbs.
        Search Google for Blaine Hoopes website, for the best detailed explanation of how these carbs work. there may be a link from xs11.com
        Bill Woods
        1981 Yamaha XS1100SH (Eleven Special)
        1985 Kawasuki GS425 Mojave ATV
        2006 Yamaha Wolverine 450 4x4 ATV
        • RiskyBusiness
          • Mar 2003
          • 174
          • Richmond, Virginia, USA
          Blaine's page
          I have not read it yet, but thanks for the tip! Looks like good stuff.
          1979 XS1100 Special with 81 carbs
