headlight out/RLU Bypass
  • clyderider
    • 41
    • minnesota
    headlight
    Yes I did check everything but the diode...and i mean everything tach works just fine replaced relay-fuse-checked battery-all wires it has a new fuse box just no darn headlight even checked lefthand control box ,everything on this bike is squeeky clean I did dielectric grease and all.so thanks if i'll have hi/lo beam then fooey on the diode I'm tired of shelling out money on this...yes I'd like it perfect but.I don't have a spare diode and don't have a clue where to purchase one.again thanks very much.
      • 2088
      You can get a diode at Radio Shack for under $5.00.I have a spare one if you need it.Give me an address and it will go out tomorrow.
      • clyderider
        • 41
        • minnesota
        headlight
        I don't know if I need one????? I have not unwrapped the original yamaha wrapping and to be honest don't want to but......if it's just 5.dollars ...well then maybe I'll check tommorow after I do a voltage check,does anyone one else have k&n pods with short fuel lines to connect to the tank??? it's a Biatch to do and not get leakage...could you please tell me the exact diode name or whatever code is necessary to get it from radio shck please and thanks yet again!!!! i mean it ....thanks from clyde too!(bikes name)
          • 2088
          This post was from a while back: A diodes voltage rating is its maximum operating voltage (600 volt diodes with work with 12 volts, 12 volt diodes, if there is such a thing, will not work at 600 volts) . I would think that any voltage rating over 200 would work for anything on the XS11 other than the secondary coil voltages going to the spark plugs.
            • 2088
            This is what i originally asked: diode question
            The diode that is in my SG and others-What is the voltage that i need for repair purposes if it goes?I went to radio shack and saw 600v diodes and other ones.
            • mro
              • 4276
              • Hayward, California
              diode
              diode, OEM spec, 1 amp 50 VDC
              I don't see why a larger capacity diode would not work.
              mro
              • clyderider
                • 41
                • minnesota
                headlight
                so I tried the jump between the blue and red wire and when I went to put the negative back on it sparked thank goodnees I did'nt have the headlight conected then removed jump and the tried the bike no negative spark when i went to hook it back up And the bike started just no light heplp gurus! gotta be something has no diode was takedn out and the white wires are wired together no burned disconected wires has new fuse box,replaced reserve lighting,it burned out the plug to the light replaced with new setup had a blown light.replaced light.replaced fuses 10amp.lots of spark no problemo there just no headlight and the jump was a nogo. .................................................. ....................................fork brace,k&n pods,short bandle bars,oury grips,steel brake lines,new seat,1979 SF (clyde)
                • clyderider
                  • 41
                  • minnesota
                  head light
                  that sounded confusing to me I meant to say Orignally the light blewout and the plug behind it in the headlight was melted some.so I replaced the plug with new and reserve lighting unit,and fuses10 amp....just the jump was a definetly nogo! help please....gotta have light
                  • clyderider
                    • 41
                    • minnesota
                    reserve lighting bypass
                    if i wanted to bypass reserve lighting how would i do that?............................................. .................................................. .................................................. ........................79xs/sf fork braces,k&npods,steel brake lines, oury grips,new seat fuse box replacement,new clutch
                      • 2088
                      Maybe this will help- reserve lighting bypass
                      Ok. I got a barn bike (found in a barn) Lots of wire problem
                      I restored a 1977 750 triple, I took out the reserve lighting unit.
                      I want to do the same with this bike is there a thred for this?
                      Report this post to a moderator | IP: Logged
                      Old Post 04-05-2008 03:56 PM
                      TopCatGr58 is offline Click Here to See the Profile for TopCatGr58 Click here to Send TopCatGr58 a Private Message Find more posts by TopCatGr58 Add TopCatGr58 to your buddy list Edit/Delete Message Reply w/Quote
                      TopCatGr58
                      Yep,
                      Take a look at the tech tips, either from the left column, or scrolling down from the MAIN FORUM PAGE, lots of new tips that are NOT linked from the left column!
                      Old Post 04-06-2008 03:52 AM
                      wa407mpp is offline Click Here to See the Profile for wa407mpp Click here to Send wa407mpp a Private Message Find more posts by wa407mpp Add wa407mpp to your buddy list Edit/Delete Message Reply w/Quote
                      wa407mpp
                      I feel like I fell asleep in class and missed something important. Why would any sane person want to remove the reserve lighting unit? Speaking as someone who has lost the gift of light at some bad times over the years this is something I would never do. or am I the only one here who rides in the dark?
                      __________________
                      Fastmover
                      "Just plant us in the damn garden with the stupid lion" SHL
                      Old Post 04-06-2008 03:54 AM
                      prometheus578 is offline Click Here to See the Profile for prometheus578 Click here to Send prometheus578 a Private Message Find more posts by prometheus578 Add prometheus578 to your buddy list Edit/Delete Message Reply w/Quote
                      prometheus578
                      Moderator "X"traordinaire
                      Or do you just walk around in the dark about most things?
                      I see no reason to remove it, either. Came in handy once.
                      __________________
                        • 2088
                        I found in the search column alot of info about the bypass.
                          Using the string rlu in the search button at the top of the page will bring up quite a few threads talking about the reserve lighting unit. For examplke, this one has a procedure to jumper around the RLU.
                          HTH
                            Hey Cyclerider,
                            I merged your several threads on this same topic/problem to help keep the suggestions and train of thought on the same line!!
                            Jumping the blue/red wires of the headlight RELAY just sends power directly to the RLU as soon as the bike is turned on without the required charging signal from the yellow wire activating the relay.
                            However, the RLU is the next link in the chain, and they also have been known to go bad. As per Ken Talbot's suggestion, bypassing it should finally get you the headlight. Perhaps it is shorting out internally, hence the spark on the battery neg. cable reattachment when you had the blue/red wires jumped??
                            It would be best to find and reply to this thread to continue troubleshooting vs. starting new threads!
                            • clyderider
                              • 41
                              • minnesota
                              headlight out
                              Yes thankyou..i get impatient when my bikes down and I can't solve the issue immediately.again thanks for eveyones help.I get the dunce hat now.............................................79 xs/sf clyde.....fork brace/pods/stainless steel brake lines/new fuse box/4-1 kerker exhaust/new seat cover/short hadle bars/pc coil redone.last thing was gonna be mike xs coils and new wires/caps.....getting there. thanks guys.
