Ultrasonic Cleaning
  • latexeses
    • Jun 2008
    • 1491
    • California
    Ultrasonic Cleaning
    When I first bought the 79SF I yanked the bowls off the carbs to check the general shape of the beast. Cleaned up the little bit of the "green" gas residue with Gunk carb cleaner and took everything apart that I could from the bottom. Hosed out all the tubes and nooks and crannies. Also hosed the outside as well. Made them look better anyway.
    Today I took the #4 carb apart and put the body into a small ultrasonic cleaner. It's big enough to put two carb bodies in at once. Dropped the smaller parts in as well.
    Used a combination of Simple Green and Dawn diswashing soap and good old H20 and let it churn for about an hour.
    Holy Crap! Could not believe the amount of stuff still in there. Couldn't hardly see the bottom of the tank. Just the condition of the Aluminum inside the carb is better. Bright and shiny!
    I would have bet that carb was nearly clean inside before I started.
    What a lesson. What looks clean isn't.
    I won't bet now that it is as clean as it could be but I am a bit uncomfortable putting that aluminum body in cleaner that says to avoid "prolonged contact with aluminum".
    I'm betting it is cleaner right now than it has been in the last 28 years!
    If anyone has any doubts about the merit of using the ultasonic cleaner, my vote is a resouonding
    "Do it!"
    Again, thanks for the help I have recieved here in this forum.
    Can't wait to get this bike up and moving.
    Rodger
    Everything on hold...
  • latexeses
    • Jun 2008
    • 1491
    • California
    "resouonding? Looks like I should have studied spelling a little harder in skool.
      ultrasonik cleaner
      Latex, how much does your type of ultrasonic cleaner go for?
      • psycoreefer
        • Feb 2008
        • 1557
        • Minden, NV
        A couple weeks ago they had one on sale at harbor freight for 75 bucks. Was big enough for 2 carbs at a time.
        1979 xs1100 Special -
        My Bike:
        [link is broken]
        • ClarkGriswald
          • Aug 2008
          • 256
          • Bloomingdale, MI
          Wish I had the one at a robot plant I used to work at, you could load it up with tons of large circuit boards and put em in there.. the water jacket around the top that keeps the fumes in was run right off the main cooling lines in the plant .. then there was a small one in the hydraulic dept.. Man those were so awesome for carbs.. they had freon or contact cleaner in them that we got in 55 gal drums.
          Prob was policing it so people didnt drop oily parts in there and then all heck breaks loose if it gets contaminated hehe..
          XS1100 F/G (79 Bike/80 Motor)
          Grab a tetanus shot and jump on!!!
          • latexeses
            • Jun 2008
            • 1491
            • California
            Phil- The unit I am using is an older unit that came from a veternarian practice. Used for cleaning surgical instruments. I can't even hazard a guess at the cost. Anything that has to do with the medical field costs like it was made of platinum. Sorry.
            Has anyone looked at some of the govenment surplus sites for surplus units?
            • Winterhawk
              • Jun 2004
              • 684
              • Missouri
              Be careful that you don't leave them in to long. The Ultrasonic will turn them back and you may have to use paint remover on them to shine them back up some.
              • ClarkGriswald
                • Aug 2008
                • 256
                • Bloomingdale, MI
                It will also break down the cartilage in your hands/joints if you dont keep em outta there while its running.. Just incase yall didnt know.
                • latexeses
                  • Jun 2008
                  • 1491
                  • California
                  Now I know why I went to using smooth jawed forceps after the first time I stuck my hand in there!
                  • latexeses
                    • Jun 2008
                    • 1491
                    • California
                    Bikerphil-
                    LATEX?
                    Oh, latex is just so 80's. I like a nice cotton blend. Much more comforable and keeps one from all that dreadful sweating while one is out on the town. Not sexy at all. The heat in some of those clubs can be so oppressive. LOL
                    Man, I guess I better change my handle before someone gets the wrong idea! Way off! Hope that latex monikier doesn't stick. Maybe somethng like late-xses. It's all good.
                      But you have '79 XS's. With 1100's, that would be earlyxeses. Or mabye your XS's have gone to the boneyard (late-xeses).
                      • latexeses
                        • Jun 2008
                        • 1491
                        • California
                        True-But an "as of late" owner as opposed to an "early owner".
                        Sent you a PM about the cleaner.
