Needle and seat crossover numbers?
  • latexeses
    • Jun 2008
    • 1491
    • California
    Greetings to those most knowlegable,
    I have dove head long into the carbs on the 79sf and so far the only parts needed for the rebuild are two worn needle valves and seats. I am going to replace the lot and start fresh.
    Took the advice I have read here about Mike's XS but am confused as to what the crossover numbers are for xs650 to xs1100.
    The seats I have look like the BS38 CV carbs on Mike's site but there are two sets there that look the same. Part numbers 48-5019 and #48-1429. I don't see any others that look similar to the needle and seats I pulled.
    I have hunted the forums for the correct numbers but have drawn a blank. Didn't want to Mike's and ask about parts for the 1100, having read here, about that it might be a tender subject.
    Just point me in the right direction if the numbers are already posted in the forums somwhere.
    I have been around this online group since late June and the wealth of practical knowledge here is astounding. Of course there is a corresponding ammount of BS, which my dad used to say, "Balances the world".
    Thanks much for any assist.
    Rodger
    Everything on hold...
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    The Yamaha part number for the needle valve & seat assembly for your bike is 1J7-14190-20-00.
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
      float valves
      The info. you are requesting should be in this thread...
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        You can get them at this site for 12 bucks each and that includes a bowl gasket. It's the fourth one down. Part#48-1407
        23mm float height
        120 main jets
        42.5 pilot jets
        spade fusebox
        • latexeses
          • Jun 2008
          • 1491
          • California
          Thank you for your direction. Helpful as always.
          Someday I'll learn the correct key words to hunt these down and quit bothering eveyone.
          Thanks again for the help.
          Rodger
