spooge hole cleanout
  • redbone
    • Oct 2007
    • 244
    • Waynesboro pa
    o.k. so this past wknd i did the spooge hole cleanout cuz my calipers were hangin up. front was relatively clean rear was real bad. took for test ride. seems fronts no longer hang up, seems rear still does. so i get to thinkin....do to the fact that the spooge hole is so small that the **** from an ant would clog it.., i wonder what would happen if it was drilled a little larger. now, i did not do it, but was wonderin if anyone else ever did??
    any info appreciated.
    redbone
    1980 mns1100
    testing 1-2-3
    1980 1100 mns
    dragging brakes
    Don't know about the spooge hole modification, but if your rear caliper is still hanging up, the caliper itself probably needs cleaning. Cr@p builds up in back of the piston seal and the piston won't move smoothly. Clean it out using only new brake fluid and a small scraping tool. HTH
    • boyat68
      • Oct 2007
      • 358
      • Virginia
      redbone:
      That hole is extremely small and hard to see as well as getting a small piece of stiff wire into it to clean out the gunk blocking it. A piece of a wire brush steel bristle will probably fit and push the gunk out where it can be dissolved by some fresh Dot 3.
      • Codger
        • Dec 2005
        • 27
        • Iowa
        Spooge Hole?
        Yes indeed I had the same problem- and I did drill out that pesky orifice with a very fine bit. That was some 10k miles ago- no problems- no more dragging calipers- no noticeable loss of braking power. Used a small vacuum to collect any small shavings the operation might generate. It worked- at least in my case.
        • Yamaniac
          • Jul 2005
          • 262
          • Stilwell, KS
          You don't remember what size of drill bit you used by chance?
          Yamaniac
          '79 xs11 sf - WidowMaker, 750 final drive
          '80 xs1100 sg- ENEMY#1 parts bike no title(free)
          '79 f- frame and swingarm (and title)
          '82 yz 490- needs a cylinder, head, & new piston, etc. Got one for sale?
          '88 Honda cbr600- Running, finally! Training bike for swmbo, maybe a stunt bike for me eventually.
            You can use a fine strand of copper wire, from some 18-20 gauge wire to clean out the spooge hole.
