Does anyone know what brake parts fit what years? Does a 78 ft calipers fit a 80G? What about master cyl? Thanks Den
brake parts swap?
As far as I know, ALL rear calipers and M/C's interchange, only the mounting plates for the calipers are different. The front, however, is a different story. Standard and special have different fork legs and calipers, will not interchange. The front M/C's are also different in the fact that the special M/C is angled to conform to the buckhorn bars, and the brake hose from M/C to junction block is longer. The M/C's and calipers have the same bores and can be used with each other, ie; special M/C with std front, and vice versa. The entire front (triple trees, fork tube and lowers) can be used on both std or special if entire front is used. Hope this helps.put something smooooth betwen your legs, XS eleven
79 F (Blueballs)
79 SF (Redbutt)
81 LH (organ donor)
79 XS 650S (gone to MC heaven)
76 CB 750 (gone to MC heaven)
rover has spoken -
Hi Den,
pads & calipers swap on ALL the XS series bikes from post '77 XS650 on up. For Standards, that is. The larger engine Specials, XS750S?, XS850S? XS11S? all have the forward axle fork sliders and ATE style swivelling front calipers and those ATE calipers don't swap with nothin'Fred Hill, S'toon
"The Flying Pumpkin"Comment
Hi, Just wondering as to the setup on the front of the XS1100RH which has leading axle fork sliders but a standard type of brake caliper. I met a guy a few weeks ago who rode one, and we were noting differences between my '79SF and his RH. It's got me thinking about fork seals etc in his case, as I'm having enough dramas sourcing front end bits for mine
Regards,
Errol79 SF Special W/ Stock all original motor @ 384,000klms
*"The Keg"- UC torana hubs, XS11 discs, Tokico 4 spot calipersComment
