I got my hands on a set of the K&N knock off filters. I have seen posts about the rubber insert closing off the jet ports. I also found the filters fell off the rubber piece too easily when installed.
Here is what I came up with. I bet you are all jealous of my stupendous phortagrafical skillz.
Too a spare airbox and removed the tubes:
I cut the tubes just aft of the retaining groove:
Removed the rubber insert from the pod filters:
Crammed the tube into the pod filter. It is a chore, but it will go. Much more snug than the rubber insert included with the filter.
Noticable difference in power. Nothing earth shattering, but there is a boost. I also found a breather filter that looks similar to these at Oreilley's, for about $10. Not bad for less than $50
