Reserve Lighting Unit
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    OK. I think the PO removed mine.
    What do you all think??
    If I remember correctly with out it my Hi Beam will not come on if my Low Beam dies?
    Is this why my headlight does not come on until I start the bike also?
    Thanks all
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
  • Montreux_Blue
    XS-XJ Guru (Deceased)
    • 1143
    That is a standard feature, the light doesn't come on until you start the bike. I'm sure it is so all the power goes to the starter.
    Famous Myspace quote:
      I don't know what is going on inside th tape, but that a look at the way I bipassed all of mine:
      • mro
        • 4276
        • Hayward, California
        Head light is turned on by the head light relay.
        The relay is activated by the AC generator.
        (the wire from generator has an in-line diode to make DC current for the relay)
        mro
          Geez, that was unintelligible! It should have read, "I don't know what is going on inside the tape, but take a look at the way I bypassed all of mine:"
          http://home.comcast.net/~sidhansen/rlu/rlu.htm
            Whew, ws gtting worrried four a minut thair, Sid!!
            • MrOzz
              • Aug 2008
              • 782
              • Massachusetts
              Skids,
              I knew what you ment. Thanks. Im going to pull the tape off and fix it nice and neat.
              Thanks for the schematic.
              Ozz
              1980 XS 1100SG
              Pod Filters
              DynoJet Kit
              T.C.'s Fuse Block
              V-Max Auto CCT
