Electrical Gurus Please
  • subike
    • 167
    • Christchurch New Zealand
    I have a 1979 F. it had the square clocks
    I am fitting the 1980SF round clock cluster.
    The F cluster has a fuel gage, the SF cluster has a warning light
    Q1 Is the sender unit compatabile,
    The F cluster has two warning lights for the signal lamps
    The SF cluster has a single warning light for the signal lamps.
    Q 2... Can somebody draw a symatic for the re wireing of the SF clocks to the F wireing loom.
    Photos?
    As I have removed my wire loom to paint the bikes frame , I am now refitting it. The manuel is not very clear as the where the wires are routed.
    Q3.Can somebody give me a link to clear photos of the main wireing harnes fitted to a frame , pic from above. Or a serries of pics showing the location of all relays ,block connetors, control boxes , mounted in their locations,
    ie, a pick of behind the fuse box panel so I can route my loom the correct way.Thanks
    Q4.Signal flasher. To remove self canceller, ...fitting a stand car flasher unit should do this?
    Q5.Head Lamps . What is the max wattage bulbs you can use with the std headlight relay, thinking twin bulbs. Or is it a better option to wire in headlight relay from a car, bypassing the std relay.
    I am able to do the work myself, just need pics and or suggestions for this work.
    Each of you will have your own ideas on these Q's, I would like to hear them , or links explaining them.
    http://i139.photobucket.com/albums/q...e/DSC00009.jpg
    1980 XS1100 Std English Assembled, 378k miles
    In stock untouched contion.
    http://i139.photobucket.com/albums/q...e/seatside.jpg
    1979 XS1100F Std NZ new,
    Mikes XS coils
    Jardine 4-1
    Pod filters
    Harley Davidson Rear Fender
    Bullet signal lights
    Twin 75mm headlights
    Self made single seat
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    I'm not 100% sure but I think the SF's utilize more of a sensor to activate the fuel warning light whereas the F's (standards) use an actual float. BTW SF is a 79, 80's were SG's
    There was an excellent CD offered on this site and contained in it was all of the wiring routing diagrams. Don't know if it is still offered.
    2 prong auto flasher I believe will work.
    Ernie
    • 81xsproject
      • 3185
      • Fortuna, CA
      You just need to get the different sending unit out of a special tank. I am pretty sure they are a direct swap. I am swapping to a standard tank and dealing with the same problem.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
      • Crazcnuk
        • 2980
        • Hinton, AB, Canada
        Q4: Yes. You need a 2 prong flasher.
        Q5: Go with HID(s) LESS watts, but lots more light.
        '05 ST1300
