Float Bowl Gaskets
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    Float Bowl Gaskets
    Ok I'am confused again, no big surprise really.
    I want to clean my carbs, I'm having a few issues.
    I went to parts and more so I can order the float bowl gaskets. When I looked, I saw a carb rebuild kit, Part#48-1408. The float bowl gasket is different than Part#20-7024. Is the something I should worry about? Or is it the same? Should I order the gasket from somewhere else?
    What I need is the float bowl gasket for a 1980 xs1100 special.
    Thanks again for all your help.
    Ozz
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
  • Montreux_Blue
    XS-XJ Guru (Deceased)
    • 1143
    I asked TC about that the other day and he said the Part#20-7024 is wrong and you don't need it anyways because the CARB REBUILD KIT Part#48-1408 comes with the correct float bowl gasket. So if you only need the gasket then I guess you'll have to look somewhere else or order 4 CARB REBUILD KITS!
    Famous Myspace quote:
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      I thought so.
      Thanks again Montreux Blue for your help.
      But if I just wanted the gaskets any ideas where to get them?
      1980 XS 1100SG
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • mro
        • 4276
        • Hayward, California
        Click >> http://www.carbkitscapital.com/carb_...at_Bowl_Gasket
        Near bottom of page, $3.00 ea
        Georgefix on ebay should have em too.
        Bikebandit.com is another
        mro
        • MrOzz
          • Aug 2008
          • 782
          • Massachusetts
          mro
          Thanks MRO,
          Do you know if the Carb kit shown here, http://www.carbkitscapital.com/carb_...a&model=XS1100 , Part #48-1408 work on the 80 special? Looks like it should.
          Also, have you purchased from them before? Where you satified with them?
          Thanks again MRO
          1980 XS 1100SG
          Pod Filters
          DynoJet Kit
          T.C.'s Fuse Block
          V-Max Auto CCT
          • mro
            • 4276
            Part #48-1408 will work, but can be found cheeper.
            http://www.mikesxs.net/mikesxs-fuel_...ategory_id=4.3
            mro
            • mro
              • 4276
              BTW
              Mikesxs.com is a XS650 site.
              There are several items that can be used either on 650's or 1100's.
              Have to pay attension to decrptions
              Also check if cost of freight is worth buying from more than one site.
              mro
              • TADracer
                • 1417
                • Kenner, Louisiana USA
                Remember, in a pinch you can always make them. I have done this before and the fuel hardened, used gasket made an excellent template.
                But the factory cut gaskets are better if you can get them.
                Mike Giroir
                79 XS-1100 Special
