Which bolt is the "locking" bolt on the assembly....the smaller outer one, or the larger inner one?
Cam chain tensioner
Cam chain tensioner
'81H (my first XS ) "Grey Ghost"
4:1 Jardine w/ headerwrap
Windjammer(wiring issues)
New paint/brakes to come!!
'80G FrankenBike (parts bike)
'80G to fix "BlackSunshine"
Stock Pilots/125 mains
Pod filters; 4:1 Kerker??
SS Brake lines w/ new M/C's
LED Brake Lite
Needs paint....
It is better to be thought a fool than to open ones mouth and remove all doubt....Tags: None -
???? Huh?
There's a plunger inside the tensioner. There's two allen screws on the front that hold it to the block, then on the side, (Right side of the bike, left if you're looking at the adjuster from the front) there's a bolt with a nut. This bolt is the locking bolt, and the nut is there to make sure the locking bolt doesn't "Unlock"! lol.
The aluminum housings on these adjusters is easy to strip, so use a torque wrench when tightening this nut and bolt.
*Crashed/Totalled, still own -
the aluminum housing has a large "nut" with a smaller bolt on it on the side...(left side if you are looking from the front of bike)
i dont want to strip it out...so do i loosen the smaller nut, then the larger one, or vice versa?'81H (my first XS ) "Grey Ghost"
LED Brake Lite
Needs paint....
It is better to be thought a fool than to open ones mouth and remove all doubt....Comment
Take it off and check it out
I know you might not want to get into it this far but take it off and check it out. Only two bolts hold it on and you can make a new gasket very easily. That way you get to gain alittle knowledge and see first hand how the part works.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
planning on pulling the whole thing apart this winter...
new gaskets, checking stuff out, cleaning it...polish and paint..
new coils, wires, etc.... just trying to do this, cuz im sure it needs it. bike has 66,000 miles on it...and the last 6 years looks like it has been rough on it.'81H (my first XS ) "Grey Ghost"
LED Brake Lite
Needs paint....
groovy..thanx!!!!'81H (my first XS ) "Grey Ghost"
LED Brake Lite
Needs paint....
Did you read procedure in manual for adjusting cam chain?
mro
BTW,The aluminum housings on these adjusters is easy to strip, so use a torque wrench when tightening this nut and bolt.
Not tight enough or if stripped and you can wind up with bent valvesComment
yep...i did. but the picture is not good, and did not know which was the "lock" and which was the tensioner...'81H (my first XS ) "Grey Ghost"
LED Brake Lite
Needs paint....
