Middle&Final Gear oil
  • Sandy H
    • Sep 2006
    • 118
    • Toronto Ontario Canada
    Hi
    I put Pennzoil gear plus gl-5 sa-8--w-90 in a year ago.
    It was a nice gold color.I have gone about 3000k since then.
    I checked it last nite and it is starting to go black in color.
    Is it time for a change?
    Movin On Down The Line.
    Where Ever You Go.
    There You Are.
    '82'xj1100j Maxim
  • red bandit
    • 955
    • central michigan
    Since the season is almost over for us northern people. If it were me... I would make changing the gear oil part of my winter maintenance.
    79 SF parts bike.
    • barberad
      • 416
      • the 45th state
      In the links section there was a reference to an online manual in there. I don't remember the recommended change duration from my manual, (I just changed my M/FD oil.) but it is in there.
      Hope the link works: http://www.sendspace.com/file/0hrf4c
      Current Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
      Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
      while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650
        • 8795
        mid drive oil
        When in doubt, throw it out. I change my mid + final drive oils every 5K. 85W90 is the recommended oil.
        • TADracer
          • May 2006
          • 1417
          • Kenner, Louisiana USA
          You are probably OK as long as the level is right. It is not uncommon for the stuff to turn colors. Since it is in a closed system and not subject to combustion blowby and acids like engine oil it should not degrade as fast. I change mine every Spring when I do a major 'go through everything' tuneup.
          I use 85/90 full synthetic for the gear drives.
          Mike Giroir
          79 XS-1100 Special
