I know this is a familiar question to most
But I am changing my filter and oil for the Talimena Rally and cannot find the hidden oil drain bolt in a deep recess.
The large bolt in center line at the rear of the engine is the middle gear drain, I know.
There is a flanged bolt located in a recess on the left side toward the engine front and kind of inline with the filter and forward of the main oil drain bolt which may be it. It is also slightly hidden by the frame tube and would require a knuckle drive to remove.
Any help in describing or PIX of where this drain is will help out very much
Thanks
Dell82
But I am changing my filter and oil for the Talimena Rally and cannot find the hidden oil drain bolt in a deep recess. The large bolt in center line at the rear of the engine is the middle gear drain, I know.
Thanks
Dell82
