Mounting saddlebags - turn signal hole
  • Chuckster
    • 93
    • Crystal Lake, IL
    I'm mounting a pair of Vetter saddlebags on my '78 Std. and I need to use the turn signal mounting holes. It's a large diameter hole with a rubber bushing in there for the turn signal that allows the turn signal to absorb shock. There's a large steel washer on the back of the bushing behind the frame. I'm not sure if I should leave the rubber bushing in there and mount the bracket for the bags to it or not. On one hand it would give the bags some shock absorption, but it's a little worrisome because the bags/bracket moves a little. I'm just not sure if it's secure enough. Anyone dealt with this before? Any advice would be appreciated.
    Regards,
    Chuckster
    Chuckster
    '78 XS1100E
    Money can't buy happiness, but it can get you an XS11 and that's a start.
  • strabo
    • 21
    • Maplewood,MN
    On my '82, I've got the vetter side bags. Mounted thru turn signal holes.
    I just left the rubber grommets in. Large washer front and back of hole bolted up to bracket. Works well for me. No danger of bracket dislodging itself. Have run like this for 8 years with no worries
    '82 xj1100 17k miles
    '82 XJ1100 30k miles
    '82 XJ1100 90k miles <stuck in 2nd gear>
    • Chuckster
      • 93
      • Crystal Lake, IL
      Thanks strabo, that's just what I need to hear!
      Chuckster
      '78 XS1100E
        On both of our '81 H models with the full Vetter package, the carriers for the saddlbags are bolted through the signal mounting location without any rubber.
        FWIW...
