Cracked carb boots
  • barberad
    • 416
    • the 45th state
    Cracked carb boots
    After looking at the XSchops and cokemans bike pics, I decided tp remove the 2 cans of krylon the PO left on the engine for me. after it was all said and done I really notice the cracked carb boots.
    I am thinking of fixing them, off the bike, this way: Scrub them down with simple green, wipe them down with acetone (nail polish remover) because it leaves no residue, and cap them off and spray them with Dip-it (liquid rubber). Anyone have any other ideas?
    Current Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
    Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
    while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650
  • thewiz
    • Oct 2006
    • 1115
    • Wilksboro, NC
    Yup ... somethin' like that's ..
    been done before. People even have wrapped them with 2in. electrical tape .... several solutions can be found here on this site with a search.
    Fact is: much of the time the external cracks don't go all the way throught the boot and thus; not really a problem. New ones can be had here for 90 bucks.
    80G Mini-bagger
    Past XS11s
    • mro
      • 4276
      • Hayward, California
      From 3 feet away...
      electrical tape looks pretty good.
      mro
      • barberad
        • 416
        • the 45th state
        Thats been my take on all my bikes...but than it's 10 feet away and only at night, but under a street light is okay.
        • scott0757
          • Jun 2007
          • 130
          • Syracuse, NY
          I gave up as none of the coatings seemed to work and would break down with the gas fume exposture.
          I found a full set of boots for under $100 at PartsNMore.com. They are great and the bike runs soooooo much better since installing them. I'd go that way.
          Past Rides:
          1969 OSSA 250 Pioneer
          1979 XS650 Special
          1978 Honda CB750K
          Current: 1980 XS1100SG
          • dbeardslee
            • 4385
            • Maineville, OH
            Barberad - mine were pretty badly cracked so I took 'em off, cleaned 'em and roughed 'em up good, and applied ten coats of plastidip spray. That was at the beginning of the summer and they are holding up beautifully, and you don't have to be ten feet away to admire them. The trick is to apply all ten coats on the same day allowing about 30 minutes dry time in between. If you put some on and let them sit overnight, the next coats will bubble.
            In fairness, mine were only cracked on the outside. The inner tunnels were still in good shape. I masked the openings and the vacuum ports, and just applied it to the outside. If they were cracked on the inside I think I would have bought new ones.
            • barberad
              • 416
              • the 45th state
              dbeardslee- thanks I'll try it the way you suggested.
              • kjohnson
                • Aug 2007
                • 202
                • Wetaskiwin, Alberta, Canada
                Mine were cracked, but not too bad. all I did was cleaned them up to remove grease, oil and dirt, then coated the cracks with black RTV silicone. You can defiantly tell that it is there, but that doesn't really matter to me at this time. the bike needs a lot more TLC to look good.
                K. Johnson
                -1978 XS750SF - brought back from the dead with carb
                triple clean and boots
                -1982 XJ1100J - brought back from the dead by
                replacing motor after throwing #4 rod
                -1985 XJ750XN - shim job, oil change, ride. not bad for
                $500 including new rear tire.
                • scott0757
                  • Jun 2007
                  • 130
                  • Syracuse, NY
                  I also tried 2-3 coats of the spray-on rubber tool handle coating. It did make a good film, but when cracks began to form near the carb hose-style clamps, it just lacked the strength when wrestling on the carb bank.
                  Anyway, the new ones are done and they made a BIG difference. Good luck!
                  Past Rides:
                  1979 XS650 Special
                  1978 Honda CB750K
