Calling all Canuks
  • Sandy H
    • Sep 2006
    • 118
    • Toronto Ontario Canada
    Calling all Canuks
    I am a (old school ) and am still having a tough time with this conversion stuff.
    Here is my dilema.
    I have a 82 xj 1100 maxum with a 19litre(5 gallon)tank.
    I have been reading on the site of how many miles to the gallon every one is getting.
    How about us guys and dolls in Canada eh!
    How many kilometers do you get to a tank?
    The reason being that when my fuel gauge gets down to 1 bar I
    still have 9 liters left.I am also using Shell v-power 91.
    Also how much fuel does the reserve tank hold.
    What happens when you run out of fuel(reserve as well).
    When you fuel up do you turn off the pet cocks,how does the reserve fill up.
    These may be silly questions,but I am going for a road trip and I would kinda like to know these things.
    Movin On Down The Line.
    Where Ever You Go.
    There You Are.
    '82'xj1100j Maxim
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    Hit reserve on my 79 special today. 178 kms ridden and put back 12.5 litres in a 15 litre tank. I'm assuming my reserve is about 3 litres.
    When you run out of reserve...the bike shuts down...no fuel...no go.
    The petcocks generally work on the regular supply tube being higher then the reserve. Its all one compartment but when the fuel gets below the main supply tube the bike will sputter letting you know fuel is low and allowing you to find a gas station by switching to reserve.
    I have always relied on my odometer to tell me when I need fuel and not a gauge. Still use tripmeters in my cages and know roughly when I need to fill up. Every bike will use a little more of less then another one based on the tune of the bike and the way it is ridden.
    Ernie
    • blue giant
      • Aug 2007
      • 880
      • Ontario, Canada
      Sandy,
      Based on my fuel mileage for my trip to XS East in May, my XJ1100 will go close to 300 kms per tank. I never went that far before looking for fuel for fear of running out. There is no separate tank for reserve fuel just a port lower in the tank that fuel flows through when the petcocks are switched to reserve. I have run my bike down to where the fuel light is on and I have had to switch to reserve but I do not remember how many liters it took to fill the tank.
      Hope this helps,
      Paul
      Paul
      1983 XJ1100 Maxim
      1979 XS1100 Standard
      1980 XS1100 Special
      • Sandy H
        • Sep 2006
        • 118
        Calling all Canucks
        I am not getting very good milage.
        When I had to change the emulsion tubes(brass)they had a lot more holes than the originals.I wonder if that has anything to do with it.
        I am going to fill up to-day and go by the odometer.
        I will keep you posted
        Where Ever You Go.
        There You Are.
        '82'xj1100j Maxim
          Hi Sandy,
          Where are you going? I bet your bum won't go 300km without a break anyway so what is the problem
          I know mine won't
          Maxim Phil
          • Axel
            • May 2007
            • 869
            • Renfrew,Ontario
            stats
            I was getting about 40 mpg Canadian before my coil upgrade and I suspect I'm doing better now.
            The XJ tank has a 19 litre (4.18 imperial gal ,5.02 US gal ) capacity with a
            4.1 litre (0.9 imperial gal, 1.09 US gal ) reserve .
            Blue giant explained how it works , no turning of the petcocks is necesary to fill reserve .
            My XJ goes onto reserve when it hits one bar .I have never seen the warning light come on . I imagine this is not accurate and can be different for each bike .
            40 mpg imperial = 33 mpg US or 14 km/litre or 7 litres/100 km
            I have been getting about 250 km before reserve approx.
            When it runs out of fuel in the main tank it starts to miss and spit and fart and then I turn the petcocks to reserve or prime . It takes a bit of time to return to normal once the carbs have been starved so I usually turn to reserve as soon (or sooner) as this starts .
            Last fill-up from when it went on reserve was 18.869 litres on the reciept . I like shell V-power too (watch your paint) !
            XJ1100K
            Avon rubber
            MikesXS black coils
            Iridium plugs w/ 1k caps
            MikesXS front master
            Loud Horns (Stebel/Fiamm)
            Progressive fork springs
            CIBIE headlight reflector
            YICS Eliminator
            • Rubin
              • Apr 2003
              • 115
              • Windsor, Ont
              I have switched over to the 850 final drive and upgraded my coils as well. I get about 300 km per tank at 120 - 130 average speed with hard luggage - usually full and only in Michigan. I still seem to average about 34 to 38 mpg though with a rare visit over 40 if I keep the speed down to about 80 on the smaller highways in Canada. I keep to the cheap gas, never noticed any improvement in economy with the better stuff. I do toss in some seafoam though and it seems to clean her out well and she runs much better for a while.
              1984 XJ1100 - 79 cams, XS850 FD, XS triple tree/euro cafe bars, hydraulic clutch, bar end mirrors, yamaha R1 rear mono-shock
              1972 CL350 - clubmans, Mike's XS coils/condenser, '98 Yamaha R1 rearsets (If I can find some at a decent price)
              • Sandy H
                • Sep 2006
                • 118
                Rubin said he aded some Sea foam.
                Just exactly what does that do?
                Where Ever You Go.
                There You Are.
                '82'xj1100j Maxim
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  Seafoam
                  Cleans out your fuel system when running or long term soaking for tough gummed up carbs . I use it for fuel stabilizer over Winter . Carbs come out squeeky clean in Spring .
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  YICS Eliminator
                  • Sandy H
                    • Sep 2006
                    • 118
                    Thx for the help.
                    There is a Napa store on the way to work.
                    I can pick dome up there.
                    Does Crappy Tire have it?
                    Where Ever You Go.
                    There You Are.
                    '82'xj1100j Maxim
                      • 3180
                      Our Napa here definatly has it but I have not seen it in Crappy tire at all. However every store has some differences so you may get it there. Seafoam goes for under $7.00 here.
                      • BrianB
                        • 362
                        • Idaho
                        You guys have a store called "Crappy Tire"? LMAO!!!!
                        I have never heard of that.
                        1980 XS Eleven Special
                        • Axel
                          • May 2007
                          • 869
                          • Renfrew,Ontario
                          Crappy nickname
                          I was wondering what you would think of that .
                          Crappy tire is our nickname for Canadian Tire .
                          Weird huh ?
                          Only in Canada ...
                          XJ1100K
                          Avon rubber
                          MikesXS black coils
                          YICS Eliminator
