reg air box or pods
  • TONIO
    • 60
    • HOUSTON TEXAS
    reg air box or pods
    Hey guy's need you advice I am looking tor post on subject thought i had seen it before I am wondering if pods would do better on my bike can anybody give me some pros and cons
    i have the 81 xs11oo special. thanks for the info in advance
    tonio
    81 xs eleven special
  • randy
    • Dec 2003
    • 4521
    You're going to get about a hundred different opinions on this. personally, my opinion is if you have the stock exhaust, stick with the stock airbox.
    • XSPastor
      • Oct 2007
      • 602
      • Gaithersburg, MD
      I agree with Randy. Pods open up a whole new can of worms because they drastically change the way the engine breathes. Plan on rejetting the carbs if you make the change. Stock airbox and exhaust is best! IMHO
      Tim Ripley - Gaithersburg, MD
      23mm float height
      120 main jets
      42.5 pilot jets
      drilled stock airbox with K&N
      Jardine 4 to 1 Exhaust
      spade fusebox
      1st and 2nd gear fix
      • TADracer
        • 1417
        • Kenner, Louisiana USA
        Yes, what Randy and Tim said. Changing one thing will affect other things. Most simple bolt-ons are simple to bolt on and then not so simple to ADJUST.
        I have pods and aftermarket 4-1 on my 79 special and it has taken rejetting the carbs and a bit of cam degreeing to take advantage of these simple mods and remove the resulting flat spots in the power curve.
        If you are not into doing more than just bolting on the pods then keep the stock air box.
        Mike Giroir
        79 XS-1100 Special
        • TONIO
          • 60
          • HOUSTON TEXAS
          pods
          thanks fellas thats what i had remembered from reading the posts in the past just wanted to make sure before i get in to deep im not as mechanically inclined as i wish to be. will be keeping the stock air box.
          Thanks agian
          Tonio
          tonio
          • petejw
            • 2269
            • sydney australia
            i agree with all the above
            but if u wanted to use pods
            the 81 carbs r the ones 2 use imho.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              Are pods better?
              On an otherwise stock bike most likely not because you must adjust the jet sizes if you fit pods just to keep the same performance.
              But will pods let you take the carbs off in 1/10th of the time and without loosing any blood or skin or patience?
              You betcha!
              And besides, pods are magic.
              With the stock airbox in place my carbs plugged up at all too frequent intervals.
              Since I removed that accursรฉd thing and fitted four UNIpods instead the carbs haven't plugged up at all.
              • XSPastor
                • Oct 2007
                • 602
                • Gaithersburg, MD
                Hmmmm. The stock airbox made your carbs "plug up?" Two things plug carbs: stuff in the gas and stuff in the air. Maybe your stock airbox had a leak that allowed unfiltered air to enter the carbs. Maybe the PO drilled holes in the wrong place in the stock airbox. The airbox, if correctly installed and functioning should have no bearing on the frequency of carbs "plugging up."
                23mm float height
                120 main jets
                42.5 pilot jets
                spade fusebox
                • randy
                  • Dec 2003
                  • 4521
                  Or maybe it was blow-by?
                  • XSPastor
                    • Oct 2007
                    • 602
                    • Gaithersburg, MD
                    In my mind blow-by would seem to be a constant determined by the state of the cylinders and piston rings. I don't see how it would be effected by the airbox.
                    I guess since blow-by gasses are not routed to the airbox with pods, there could be some difference. Blow-by would be unburned fuel mixture and would richen the mixture as it was breathed in through the vent hose attached to the stock airbox.
                    But even blow-by gasses come from the filtered air taken into the engine through the air filter and so should be relatively free from particulates. So how would they be contibuting to plugging up the carbs? Hey fredintoon, what part of the carb was plugging up? The little screens before the float valves? The air jets?
                    23mm float height
                    120 main jets
                    42.5 pilot jets
                    spade fusebox
                    • tiredoffixing
                      • Mar 2008
                      • 89
                      • Ohio
                      I agree it is so much easier to service the carbs with pods.
                      • randy
                        • Dec 2003
                        • 4521
                        The blow-by gasses are not filtered in the stock airbox.
                        • XSPastor
                          • Oct 2007
                          • 602
                          • Gaithersburg, MD
                          The big fat tube that comes from the engine to the airbox? Of course that air is filtered before it re-enters the engine. Anything connected to the outside of that airbox has to go through the air filter to get to the carbs. I agree it's not filtered before it gets to the airbox if that's what you mean.
                          23mm float height
                          120 main jets
                          42.5 pilot jets
                          spade fusebox
                          • XSPastor
                            • Oct 2007
                            • 602
                            • Gaithersburg, MD
                            You might be right, Randy. I forgot about all that ducting at the top of the airbox. Is that where the vent gets routed to the carbs without going through the air filter?
                            23mm float height
                            120 main jets
                            42.5 pilot jets
                            spade fusebox
                              Not what I said
                              Tim sez:- "The stock airbox made your carbs "plug up?"
                              No Tim,
                              I said the pods were magic.
                              As you sign yourself "Pastor" I'd guess you don't believe in magic so here's a mundane explanation:-
                              After my carb cleaning added up to a "quintuple clean" they were finally clean enough to run nicely over a long period. Coincident with this I got fed up with the hassle of removing the stock airbox and swapped to pods.
