Couple of ideas here:
If the chain is adjusted correctly, you may be hearing lifter noise, which is very similar, especially on a cold engine.
Also, in regard to cam chain wear, the guides in the engine wear as well. They are plastic and get grooves in them. They are plenty thick and I don't think will ever wear to the point the chain rubs metal to metal. On my bike, the chain was loose, even though the replacement engine I bought had a new chain in it. Peering through the chain galley, I saw the guides were worn as well. It is also possible the head had been milled down a bit much as well. My remedy was to chuck the tensioner housing in a lathe, and stick a live center in the bore that accepts the rod. I was able to remove about 200 thousandths of material from the mounting surface. This allows the rod to protrude farther into the engine, giving more adjustment range. I just needed some shorter bolts, and it has worked very well for over 2000 miles.
Just an idea or two.
