Rear Brake Rub
  • firecrackerboom
    • Jul 2007
    • 81
    • South Dakota
    Rear Brake Rub
    My rear brake is rubbing a bit. It squawks when i back it out of my parking space, but only half of the revolution of the wheel. I poured some water on the rotor, and the noise stopped, it is definitely rubbing. Also, when i come to a stop, my rear brakes squeak.
    Is there anything I need to do besides replace the rear brake pads? Is this a hard job?
    1979 Eleven Special - 26,000 miles.
  • geniusloerts
    • Jul 2007
    • 420
    • fayetteville, Arkansas
    easier than on the front!!
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
    • XSPastor
      • Oct 2007
      • 602
      • Gaithersburg, MD
      Replacing the pads will not clear up rubbing brakes. Make sure you use anti-squeal grease and that should clear up the squealing. If they rub XSively, then you may have a clogged fliuid return(spooge) hole in the master cylinder. They will always rub a little bit but if they rub enough to make the bike hard to push in neutral, they're rubbing too much. If they only rub for half of the disk, then the disk is warped. Check your manual for run-out specs on the disk. Clean that master cylinder, and make sure the piston moves freely in the caliper. Flush the system with new fluid and bleed. You should be good to go after that.
      Tim Ripley - Gaithersburg, MD
      23mm float height
      120 main jets
      42.5 pilot jets
      drilled stock airbox with K&N
      Jardine 4 to 1 Exhaust
      spade fusebox
      1st and 2nd gear fix
      • EGRon
        • Jul 2008
        • 30
        • Elk Grove CA
        This forum is incredible! I have exactly the same problem on my SF. Doesnt drag but I can hear it for about a half a revolution of the disc. I also have thoughts of warping. I tried to see if I coulf feel some pulsing breaking with the rear only from a decent speed with no warp symptoms. The same problem existed prio to my recent pad replacement. I am going to take apart look for the spooge hole issue, replace fluid and add a new SS rear brake line, as well as check the caliper. Sounds like I might also need a new disc. Harbor Freight sells a pretty inexpensive dial indicator for checking runout.
        EGRON
        • petejw
          • 2269
          • sydney australia
          glazed pads and discs can also cause
          a squeal, if the pads r within spec, lightly
          rub both pads and disc with sum sand paper
          to deglaze.
          All pads will rub slightly, with the rear wheel of the ground
          the wheel should spin by hand.
          also if u take the pads out, there should b a thin plate between
          the pad and calliper, this also helps to prevent squeals,
          good luck with it.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
