How to bypass auto cancel turn signal
  • BossMaverick
    • Aug 2008
    • 130
    • Montana
    I am wondering how to bypass my auto cancel turn signal relay on my '80 XS Standard.
    When I first got the bike the auto cancel gave me problems (turning off too soon, not turning off, not flashing, etc). Since I've been riding it, the unit works 90% percent of the time. I have tried to get used to having the auto feature but I still find myself operating it like a manual switch. Also, I like to turn the signal on quite a distance back while on a highway but I find the unit turning off the signal before I actually turn. I learned to ride on a manual switch and I would be happier if my XS was a manual switch.
    So, what is the easiest way to bypass the auto cancel relay?
    Thanks again!
    1980 XS1100 Standard "Touring"
    Fairing, Trunk, and Bags
    850 FD
    Fork Brace
    Progressive Front Springs
    Engine Guards w/Foot Pegs
    Oil Cooler
    Throttle Lock
    Uni Air Filter in Airbox
    2009 Suzuki Bandit 1250S ABS
  • Jerry
    XS & TRUE XJ GURU
    • 3023
    • Elma, IA.
    On my XJ, hitting the switch twice defeats the auto cancel functions. That is, if I'm turning right, I press the switch right twice within the space of a second or two and the auto-cancel is defeated.
    Jerry Fields
    '82 XJ 'Sojourn'
    '06 Concours
    My Galleries Page.
    My Blog Page.
    • kjohnson
      • Aug 2007
      • 202
      • Wetaskiwin, Alberta, Canada
      for me, i un-plugged the auto-cancelling unit as my turn signals wouldn't even work with it hooked up. now the signal stays on until i turn it off
      K. Johnson
      -1978 XS750SF - brought back from the dead with carb
      triple clean and boots
      -1982 XJ1100J - brought back from the dead by
      replacing motor after throwing #4 rod
      -1985 XJ750XN - shim job, oil change, ride. not bad for
      $500 including new rear tire.
      • BossMaverick
        • Aug 2008
        • 130
        • Montana
        Thanks guys, I will try hitting it twice and if that don't work I will try unplugging the unit.
        Thanks!
        850 FD
        Fork Brace
        Oil Cooler
        Throttle Lock
          Another way is to put in a 2 prong Electronic flasher relay, useful IF you are going to be going to LED's anyways, and it will then totally NOT use the self cancelling feature, FOREVER!
          You won't HAVE the self cancelling feature with a 2 prong flasher, and 3 pronged ones won't work at all!!
          • red bandit
            • 970
            • central michigan
            Does anyone know how to check the autocancel or speedo to see were the problem is? I have 3 autocancels and they won't cancel on my bike. Been like that since I've owned it. I have a fairing so there has been wire splicing.
            79 SF parts bike.
            • randy
              • Dec 2003
              • 4521
              red bandit;
              your first check would be the "lead switch" in the speedo, it's the White/Green and White/Black wires. You can either remove the speedo and check it on the bench or chuck your speedo cable into a drill, spin it and check for periodic continuity on the wires. the switch closes every 1/8 mile or some such giving the canceller unit it's signal.
              Or just forget it like most of us do and cancel the signal yourself.
              • psycoreefer
                • Feb 2008
                • 1557
                • Minden, NV
                If your switch is bad my speedo just broke and I've got a good switch out of it. Let me know if you need it.
                1979 xs1100 Special -
                My Bike:
                [link is broken]
                • planedick
                  • Mar 2005
                  • 2068
                  • Yorba Linda, California
                  Read switch???
                  It's actually a "reed switch" and it opens and closes as the magnets that drive the speed hand pass under it. It's the same kind of switch that is on doors in security systems. The magnet is on the door and the switch is on the jamb and it is held closed by the magnet. When the door opens the switch opens.
                  As the MC moves the cup with the magnet goes around and the reed switch opens and closes and the canceling unit counts the revs and after a set number of them it turns, off or in 10 seconds, whichever comes first.
                  Drilled airbox
                  Tkat fork brace
                  Hardly mufflers
                  late model carbs
                  Newer style fuses
                  Oil pressure guage
                  Custom security system
                  Stainless braid brake lines
                  • randy
                    • Dec 2003
                    • 4521
                    Yes, by it's construction it's a common reed switch, but the schematic calls it a "lead switch" Maybe it was due to phonetic confusion with "R" and "l"?
                    Oh, that was not politically correct, but has been known to happen!
                    • red bandit
                      • 970
                      • central michigan
                      Looks like the lead/reed switch is good. Checked for & have signal at the canceller plug too. So I guess all 3 cancellers are bad. Seems odd all 3 are bad??? Or are they short lived? Anybody ever have a canceller apart? Should I be the first? Think it might be fixable? I figure I can't hurt it.
                      Thanks for your help guys.
                      79 SF parts bike.
                      • randy
                        • Dec 2003
                        • 4521
                        Just to be clear, the canceller is the little rectangular box located by the tool box, center of the frame under the seat. they don't come apart, they're potted.
                        The flasher is the aluminum can next to the fuse panel.
                        • red bandit
                          • 970
                          • central michigan
                          Randy, yes I agree. The black potted rectangular thing. Except... EVERYTHING comes apart. Might not work afterwards but like I said, it doesn't work now so I can't hurt it.
                          79 SF parts bike.
                          • planedick
                            • Mar 2005
                            • 2068
                            Check reed switch
                            Turning the front wheel should give you on/off pulses at the canceller from the reed switch. If that's not happening, the canceller will not work. Additionally the signals are supposed to turn off after 10 seconds or 150 meters, which ever comes first. I have the owners manual and that what it says.....AIR
                            Drilled airbox
                            Tkat fork brace
                            Hardly mufflers
                            late model carbs
                            Newer style fuses
                            Oil pressure guage
                            • kf4bxd
                              • Jun 2008
                              • 17
                              • Southern middle Tn
                              They will come a part there a little peice off metal that loses connection
                              Edward / Tn
