advance wires
  • Shawnb
    • Jun 2008
    • 88
    advance wires
    I have five wires coming from tci going to advance unit on left side of engine, i have four hooked up . the fifth wire makes my nuetral light come on but i haven't hooke it up to anything does anyone know where this wire might go.
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    It connects to the neutral indicator switch located under the left side of the engine between the edge of the oil pan and the frame rail. You may have to get under the bike to see it - it's kind of inset. It looks kind of like a broken-off spark plug with a screw on the end to attach the wire.
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
    • Shawnb
      • Jun 2008
      • 88
      thank you xs pastor now if i could just get the advance to send spark to my spark plugs i will be on my way. but thanks for your help again xs pastor
        Go to the MAIN menu page, and THEN to the "Tech Tips". Look at the "pickup coil" fix. The wires are KNOWN for breaking internally. They look good, but don't work. The tip will explain everything. HTH
