Brakes
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    Brakes
    Has anyone here replaced the stock single piston calipers with with a set of double piston calipers? Haven't been real happy with the brakes on the Yellowjacket, and wonder if there is anything out there that might be better.
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    rebuild front and rear master and calipers, new pads, drill discs, stainless lines, progressives front springs, and you'll never pay attention to the brakes again, and you'll be focused on just riding defensively.
    and at any speed, the stock setup is enough even for 2 up baggers
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • pete_s
      • 115
      • NoBranford CT
      I agree, the stock system, when working, will make the front tire squeal with two two fingers on the lever.
      Between crud and corrosion in the master cylinder and hoses and calipers you are loosing hydraulic effort somewhere in the system
      1967 Bultaco Metralla 250
      RD125
      1973 CT3 175
      78 XS1100E
      80 XS850SG
