I doubt adding a single automotive relay is going to significantly increase the MTTF of the system.
Carbs drive me NUTS!!!!
Just to make clear, I went thru all my wiring on the frame before and cleaned all connections and used dielectric grease on them all.
The battery itself was measuring 11.7 VDC with no load. With a load (starter turning) it dropped to 9vdc. Both of those readings tell me my battery was low- it hasn't been driven enough to charge it . I put it on the charger and the charger pegged. I have left it on the charger all night and am going to go try it out as soon as I finish my coffee and get dressed. IF SWMBO will quit bothering me1979XS100SF
2007 Dyna wide glide
Too many dodge trucks to list!Comment
As has been said earlier ..
in this thread
"..."...it dropped to 9vdc..."
that ain't enough to fire the motor. Needs 10.4 volts.80G Mini-bagger
Past XS11s
79SF Squared-off Special, Vetter/Bates tour pkg., Mikes XS coils, G rear fender and tail light. Sold June 09Comment
Yep, that's why I left it on the charger overnight. As soon as I get dressed, the charger will be switched to my truck battery which is dead also. I have too many vehicles and I just bought another old truck this last weekend.
I seem to have started collecting 61-71 dodge trucks like some of you collect Yamahas. I currently have three trucks and a cab in my yard, two ramchargers, the Harley and the XS.
And a lady friend visiting from N.C. ! No wonder I can't find time to get stuff done
Time to see if I can actually get dressed and go try to start the XS1979XS100SF
".. a lady friend visiting from N.C..."
We must lead parallel lives .... just in the last two weeks have trimmed my pile of old vehicles down ... I was into MBZ diesels had five at one time. Sold 'em all .... last one about 2wks ago .. Whew.
Just XS11s now ... four of 'em. Plus I'm goin next week to see a lady friend in NC ... don't they talk cute down there?80G Mini-bagger
Past XS11s
My friend is my German girlfriend from 23years ago! She found me in 5 minutes on the internet and we are renewing our friendship againShe is here for one more week and I had to get the XS up as my harley really isn't meant for two up riding. The pillion seat is to small for her and I don't have a backrest, so she feels like she is going to slide off! I had to take it easy so she didn't.
BUT, now the XS is firing on all 4 and I synched the carbs. Seems to be purring like a cougar nowJust gotta take it for a test spin and see if the low end stumble is gone. I put the Iridium plugs back in and the air mixture screws are out 1.5 turns. Just need to do some chop tests and go out and have fun now!
I might even get around to putting the fairing on this week unless I am kept busy
WHEW!!! Now onto the Dodges again, after a day of test riding of course!1979XS100SF
Well, I just took it for a quick spin and it is still stumbling between 1000-3500 rpm. DAMN!!
So what else should I be checking/adjusting to get rid of the stumble? It is not as bad as it was when I first put the coils on, but it is still there1979XS100SF
I had about the same problem and no matter how much I charged the battery it still would not work. I put a new battery in it and it ran great ever sinceComment
Bro' ...
if it were me, I'd have load tested the battery with a meter right away after the overnight charge. That tells the tale of battery fitness80G Mini-bagger
Past XS11s
Man am I a DUMBS**T!
I just had to share my progress from the last 10 months.
After much frustrations and way too many lost weekends, I think I may have finally found the demon that possesed my bike and I believe I have excorcised that demonI can also remove the carbs, set the floats and reinstall them in about 1/2 hour now. That is starting at the gas tank to firing back up. I bet I could cut that in half if I got pods.
Last week while going through the electrical diagnostics with my DMM, the resistor cap on #1 finally went open all the way!! Every time I have metered it I was getting 5K +/- 10%. It was always in spec when I metered it, so I never bothered replacing them. I believe the resistor was fractured and causing current fluctuations, thus the erratic stumbling I was getting.
After a few phone calls, a trip to the Honda shop, and for under $20, I have 4 new NGK caps on the bike. Reset the carbs to just under 26MM, 2 1/2 turns out on the pilots and fired her up. After going for a run to burn off the plugs, she seems to be running pretty damn good! Just need to fine tune the carbs and change out the final drive oil seal before it gets to bad ( not leaking too bad yet, and I will have to make a seal driver for it) and it is good to go
Did I mention I am an electrician by trade and troubleshoot circuits all the time. This just goes to show, if your caps are original, REPLACE THEM!!! Best under $20 purchase you will ever make IMHO. Cheap insurance against the intermittent opens that may occur with a fractured component. Unfortunately, it may test fine over and over until the fracture finally breaks like it did on me while I had the meter connected to it and saw it go open for good.
Thanks too all who have helped out the last few years helping me get this beast back on the roadIs it normal that it seems like the faster I go, the more the power just keeps coming
I like it!!
1979XS100SF
