Do you guys think an electric carving knife would be pretty good at cutting seat foam? I really need to cut 2" off the seat. I also read that i should use rubber cement to glue the seat cover back on? Anything i should be on the lookout for while removing the seat cover?
Electric carving knife for seat foam?
I had bought the fancy King/Queen seat cover and foam, which fit nicely over the original seat pan. The problem is, the passenger would get pushed forward into me, and the seat was higher than stock. I just put the original seat cover and foam back on, and have the like new K/Q seat just sitting in my shed. I made the transformation in a couple hours.
As for removing foam padding, it's real simple. Unhook the cover from the seat pan, use some large scissors, trim the padding to your liking, and replace the vinyl. You don't have to cut the vinyl, because you can pull it tight and put the hooks in a new spot on the seat cover. I certainly would not try to cut and glue the seat cover together, since it has to bear all kinds of heat, cold, twisting of your body, etc.
John Rosko, Riding for Jesus! Make Him Lord of your life! -
Electric carving knives work GREAT on foam!Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fixComment
I use nichrome wire. you can get it at hobby stores usually. I use a car battery charger. It works on many types of foam.United States Merchant Marine Academy, Kings Point, NY
Acta Non VerbaComment
I used a mini grinder on my seat .I used a soft disc and it worked great .I was able to contour the seat cushion very quickly. You might want to do that outside and stand up wind ,a lesson learned I might add .BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
That is how Bob Jones modified his seats, using an electric carving knife."We are often so caught up in our destination that we forget to appreciate the journey." "Comment
Another safety bleat
OK, a sanding disk on an angle grinder works great for re-shaping foam; quick, leaves a nice finish and it's easy to do.
But if you look at the sanding debris under a microscope they are like little razor blades. Wear a good breathing mask while power-sanding foam, you do not want that stuff in your lungs.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Bob must have bought his carving knif from NAPA, because mine did not cut the foam fast enough!
Originally posted by Winterhawk
That is how Bob Jones modified his seats, using an electric carving knife.Skids (Sid Hansen)
Gonna go pick up the elctric carving knife. i think that would work out better since i have to pace myself lol. I'll do a better job
if it's good enough for Bob then it's good enough for everyone
1978 XS1100E Standard
Tkat Fork Brace
On Hold
TopCat S.O.F.A. + Fuse Block
Mike's XS Pod FIltersComment
wow this is a pain. already got a cut on my finger from opening up those little metal flanges that hook the seat cover onto the seat pan. this is going to take awhile heheheheh. It's gonna be worse when i have to make new holes to re-attatch the seat cover.1978 XS1100E Standard
Tkat Fork Brace
On Hold
Hi Korr,
what's even worse is when most of those little spikes snap off when you try to bend them back down again. Anyone got a better fix for that than large-head pop rivets?Fred Hill, S'toon
All done! I just put it back using the same hooks and then pulled in the extra fabric and put new holes in there for the hooks. Easy to do, but very time consuming. The electric carving knife was cutting really fast! I can now put the hole half of my foot down instead of just the tip of my toes. Thanks for all the tips guys! You really helped this go along smoothly.1978 XS1100E Standard
Tkat Fork Brace
On Hold
