Just put my new LED bulbs all over the Junkyard Dog.
It's an 80G (std) and used:
Main lights
6 1157-x24 Red Wide Angle
2 1157-X24 Amber Wide Angle
2 1157-A30-RA Amber Right Angle
I have the Vetter trunk, hence the extra 4 red lights.
Dash Lights
5 BA9s-G-x-12V 120deg Wide Angle Green
2 BA9s-A-x-12V 120deg Wide Angle Amber
1 BA9s-B-x-12V 120deg Wide Angle Blue
2 BA9s-R-x-12V 120deg Wide Angle Red
I used 4 green for my gauge back-lights, easily bright enough to see, yet not bright enough to bother you while you drive in the dark.
The extra red is for the headlight warning lamp.
I didn't order flashers (like a twit) as I thought I could get them locally, WRONG!. I've ordered 2 of the motorcycle ones.
They are much brighter than my old lights. The wide angle fills up the entire lens. Even the tail light lights all the lens. Only the 90 Deg ambers in the back signal lights are not wide angle, and they are also 30 led, making them brighter than the others.
The headlamp warning light is partially on, as usual, and during the day, it looks like the old light. At night, it lights up the whole lens, making it look like it is on, fully, almost.
The 1157's, alone, used to use 80watts! (8wx10). I hooked up the center two on the trunk as high mounted brake lights.
Only issue, is that now my high-beam indicator likes to flicker rapidly while I am on low beam sometimes...
Main lights
Dash Lights
[/IMG]
[/IMG]
[/IMG]
