Just completed installing a XS850 F/D on my 'F'.
Having a lathe, I whipped up an aluminum spacer that press fits on the drive shaft followed by an 'O' ring to act as a cushion.
I press fit 5/32 (4mm) aluminum pins into the oil holes. Should be OK because there is no pressure behind them and will only get tighter as the housing warms up. I coated them in 5 minute epoxy just to make sure they don't leak or move.
Kind of a risky move before a 2400 mile trip, but what the heck. The worse that can happen is it leaks a bit. I'll just have to keep an eye on it. I will put a couple of hundred miles on it before I leave.
Off I got for my test ride!
