Front wheel bearings
  • newmaac
    • Dec 2002
    • 369
    • San Jose, CA
    Is anybody around this afternoon?
    I am having a ^%* of a time trying to remove the front wheel bearings on my XS1100. The book says to move the spacer "out of the way" and using a drift punch, drive the bearing out.
    Well the spacer doesn't move more than about 1/32" to either side, so, there is no surface on the bearing to catch with the drift. Is there a tech tip that I have missed?
    I would REALLY like to get these things removed today so that I can get them ordered for the weekend.
    TIA,
    Mike
    Mike
    1980 SG "Angus"
  • newmaac
    • Dec 2002
    • 369
    • San Jose, CA
    Never mind. I got it.
    It turns-out that the spacer has a large washer type thing attached to one end (spacer flange). This makes it so that the spacer can only be moved aside on one end, and not the other.
    Once I knew what was actually inside the hub, it was a snap to get the bearings out.
    I will try to draw a sketch of this later to add to the tech tips. It might save someone a little frustration.
    Mike
    1980 SG "Angus"
    • sixtysix
      No XS but XSive as can be!
      • 1958
      • Central New York State
      I wrote one for the rear wheel bearing.
      Does it help you? The one side is similar.
      If I do the front I will write it up, but if you would like to take some pictures and do write up then we can post it in the tips section.
      Gary Granger
      • capocrimini
        • 41
        • Ah, ah...Kansas!
        Great expose on replacing rear bearings sixtysix, thats a job I'll be doing in the upcoming weeks when I put the new tire on back as well! Is the left side bearing from Yamaha still come w/o seals? Also, as some have tried other fixes to circumvent the cost of this exclusive bearing, has anyone pressed in 2 or 3 ball bearings that mic out to the same ID/OD and overall width? Maybe there aren't any combos of 2 or 3 bearings that will have the same dimensions as the 1 needle bearing? Would there be any load concerns doing this?
        80sg "Reaper"
