Brake Pad Life
    Brake Pad Life
    I was wondering what the average brake pad life span is under normal circumstances. I seem to be replacing a set.. either front or back (Never together so far) about as often as I change rear tires... 7-10k miles or so. I ride pretty aggressive, so I was just wondering.
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    B-pads
    I used to go thru them about a set of pads per set of tires too.....stop being a Throttle Junkie!
    MDRNF
    79F.....Not Stock
      • 2072
      I think i have only replaced my rear pads once since i owned the bike.I have replaced my front pads 3 times since i bought the bike.I use the front brake 98 % of the time so i guess that would be normal.
        I try to use pretty even braking between the front and back so the nose doesn't dive when cornering and such.. but I was just wondering what's normal. Thanks.
        Ummm... yeah.. Sure. I'll get right on that.
        • Bigfoot
          XS-XJ GURU
          • Sep 2005
          • 1422
          • Kansas City, Missouri
          you ride aggressive? never noticed. lol
          Harry
          '79 Standard
          '82 XJ1100
          '84 FJ1100
          Acta Non Verba
            • 8796
            pads
            Rears 'bout every 3 yrs, fronts 'bout every 5. I like to downshift a lot. I fix the tranny every couple years too.
