Fuel Leak
  • Filter
  • Fuel Leak
    Just bought an xs11 1980 special. My first bike. Fuel is leaking from somewhere under the right fuel petcock. I have not removed the tank (tomorrow). Does anyone have suggestions on a fix. Even in the off position, fuel is dripping at a drop every two or three seconds. Dripping gets worse when the petcock is in the on and reserve position.
    Sam Christensen
    The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
    If you are leading and no one is following, maybe your just taking a walk.
    Currently bikeless. Sold my 1980 XS1100 Special
  • #2
    It might be the rubber gasket in the petcock.Take it apart and you might be able to clean it up and reuse it.If not you can get a rebuild kit for it.Also the o-ring between petcock and tank can leak.
    80 SG XS1100
    14 Victory Cross Country
    • #3
      If tank is not rusted out,
      then one of these should solve problem.
      http://www.bikebandit.com/search-pro...100&ch=2&sc=10
      mro
