Who sells the TKAT brace? How much are they and do they really work?. Thanks
Tkat brace
Tags: None
Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fix -
"Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
Yes... stops the fork tubes from flexing/twisting. Makes things nice and solid.
Yeah, I have a set o' dem."Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
They are the one item that will make the bike handle totally different,,,,,,,,,,,very responsive, and eliminates the "wag" when being a little aggresive cornering.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I will attest to their greatness. The Tkat brace will definately stiffen up your front end. It is a very well made piece and with a bit of sanding and then some polishing adds to the looks also. Make sure you tell him if you have a standard or special as the parts are slightly different to clear the special fender.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
Tired - I love my TKat. I'm also an advocate of raising the fork tubes about 15mm above the tripple tree. The front end on these things is pretty weak, and shortening the running end of the forks a little tends to stiffen it up a bit. Also, make sure you tighten the bolts in the proper sequence for proper alignment. Basically from the top down.I think I have a loose screw behind the handlebars.
"I'm also an advocate of raising the fork tubes about 15mm above the tripple tree."
Hi 'lee,
stiffening the fork legs ain't the only thing that moving the tubes up does. You are also reducing the front wheel trail which in turn will give you quicker steering. Which is fine if you actually want quicker steering. It's one of the little tricks, like swapping in Standard 'trees on a Special, that sidecar operators use to shorten up the trail without spending $800 on a Steerite conversion or $2,000+ on an aftermarket Leading Link fork.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Fred - You got that right, brother. I was really pleased with what it did for handling. It also lowers the bike slightly giving a little lower center of gravity - also good for handling. I think the next time I put rear shocks on it I'm going with 11.5" to bring the back end down a little. I ride with a friend a lot who has a yzf 600 - he's killin' me in the twistiesYou are also reducing the front wheel trail which in turn will give you quicker steering.
"I think the next time I put rear shocks on it I'm going with 11.5" to bring the back
Hi 'lee,
while lowering the front of the bike decreases the steering head's effective rake angle to reduce the front wheel trail and thus quicken the steering, dropping the rear end increases the rake angle and slows the steering down again so you are back where you started, except for being a little nearer to the ground.
Anything you change on a bike's suspension affects everything else.Fred Hill, S'toon
