Another XJ Re-born
  • 0011mixam
    • Jan 2006
    • 42
    • Winnipeg, Manitoba, Canada
    Another XJ Re-born
    Well, thanks to a lot of help from this forum, my 82 XJ1100 is finally back on the road after almost 3 years. I discovered this gem in September, 2005. It was last registered by the original owner in 1988, and had been stored in his garden shed since then. It had been dumped on both sides more than once, and definitely needed some TLC. Here's what it looked like when I brought it home:
    I tore it down to the bare frame, which was sandblasted and painted, and started to put it back together as the bits were completed. Everything that could be dismantled has been cleaned, inspected and re-built to as-good-as-new condition. Amazingly, the engine was not seized, and the original main and rod bearings and piston rings were still within the Service Manual specs, so they were re-installed. Of course all the rubber seals had to be replaced, and most of the ball bearings in the transmission were rusted, so they had to be changed out as well. It took a while, but I was able to buy everything I needed to keep it original; a few NOS parts and many used parts through EBay. It's amazing how much is available out there for a bike that was only built for one model year (except of course for the extra couple of years up here in Canada). About the only things that I've upgraded from the original Yamaha configuration are the brake lines (stainless steel), the fuse block and the installation of an XS850 final drive. Here's what the finished product looks like (MAXIMAN, if you're still out there, you should be happy to know that your original jet-hot exhaust system found a good home!):
    Overall, it's been a very satisfying project. I do have to admit to one screw-up. When I first fired it up, it seemed to run OK, but in no time at all it dropped off the two right-hand cylinders at idle. In fact, those two cylinders were getting so much gas that they wouldn't fire, and the raw gas was filling up the crankcase. After playing around with float levels a number of times and going off on a tangent with the ignition system components, I was embarrassed to discover that all four pilot jets were loose in the carb bodies. In fact, #3 and 4 were almost falling into their respective float bowls. After tightening them up properly and re-installing the carbs, the engine fired right up on all four cylinders and I was easily able to set the idle mixtures and synch the carbs with my Morgan Carbtune.
    I've put about 250 km on the bike so far and it's a real pleasure to ride. Everything works as it should, including the self-cancelling turn signals, and the engine runs smooth and pulls like a tractor. Many thanks to all the XS'ives that have helped me with this re-build through their many posts on this forum. I couldn't have done it without you.
    I haven't thought up a name for my XJ yet, but "Second Childhood" comes to mind!
    Perry
    '82 XJ1100 (Second Childhood)
    Frame-up Restoration
    As Original as I Could Keep It
    Awesome looking bike! Nothing like the satisfaction of restoring it yourself. Enjoy!
    • SFerinTEXAS
      • Jun 2006
      • 877
      Outstanding restore job. You were a lucky soul to find it and it was lucky it was you who did.
      79SF
      XJ11
      78E
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        Beautiful. Nice work!
        Tim Ripley - Gaithersburg, MD
        23mm float height
        120 main jets
        42.5 pilot jets
        drilled stock airbox with K&N
        Jardine 4 to 1 Exhaust
        spade fusebox
        1st and 2nd gear fix
          Nicely done there, 0011. Those before pictures are just plain nasty!
          Did you build yourself a YICS tool so you can do a proper carb sync to really see how it runs?
          • tarzan
            • 1700
            • Chandler,Az.
            Wow that is way nice!So how many miles does it have total on it?It was in its time capsule for 17 years?You did a great job.It makes me want to take mine apart.LOL
            That is one of the coolest things about these old bikes.You can take them right back to new condition without breaking the bank.You have better disapline than I.Mine sat since 83,I got it last fall and I just had to get it on the road.So I just replaced the tires ,fork seals ,rebuilt carbs,etc,etc,.This winter I will do the cosmetic stuff.
            80 SG XS1100
            14 Victory Cross Country
            • Shuriken
              • 1093
              • Southwest USA
              Holy crap that is a nice restore...... hat's off to you. That bike is BEAUTIFUL. Among the best looking restores I have seen...
              Formerly:
              1982 XS650
              1980 XS1100g
              1979 XS1100sf
              1978 XS1100e donor
              • 0011mixam
                • Jan 2006
                • 42
                Thanks to all for the great feedback.
                Yes, Ken, I did build myself a YICS tool so that I could synch the carbs properly. I haven't done a full throttle chop to check the plug colour yet, but it runs so nice it can't be that far off.
                If you can believe it, my last motorcycle was a Honda 550 Four, back in 1984. I haven't been on a bike since then, until now, but it just feels so natural to get on this Maxim. Just like riding a bicycle; I guess you never forget.
                Perry
                • 0011mixam
                  • Jan 2006
                  • 42
                  Tarzan:
                  The bike had just over 30,000 km when I picked it up (around 19,000 miles). Hard to believe that someone would just park it like that, but my good fortune!
                  Perry
                  • SFerinTEXAS
                    • Jun 2006
                    • 877
                    I had a honda 550 four about 1979. Looking back it was a real clunker but I didnt know it then.
                    79SF
                    XJ11
                    78E
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      Great job! The plus side to your jet issue is that I would rather have pilot jets loose and falling out than over tight and stripped out.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                      • thewiz
                        • Oct 2006
                        • 1115
                        • Wilksboro, NC
                        Very nice .... great job !!
                        80G Mini-bagger
                        Past XS11s
                        • egleaves
                          • May 2007
                          • 441
                          • Sacramento
                          Beautiful job! you must feel a great sense of pride and satisfaction every time you look at your bike. I know I would.
                          I know this, because Tyler knows this.
                          1980 SG
                          3J6 003509
                          Kerker 4-1 (sans baffles)
                          Fuse Block Upgrade
                          Mike's XS Green Coils
                          Pods w/Homemade Velocity Stacks
                          • olebiker
                            • Aug 2007
                            • 692
                            • Kingston ON
                            Wow!
                            http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                            • Tdog
                              • Apr 2006
                              • 67
                              • Bradford Ontario Canada
                              Beautiful
                              I had to chime in here to say what a head turner that bike is. I hope you get all the looks and comments at your local "show and shine" and the posers go home!
                              Regards,
                              Tdog
                              '81 H
