Special front brakes
  • Paintman
    • Mar 2008
    • 312
    • rapid City SD
    I just finished replacing about everything brake wise from rotors to hoses. and i never had a problem but im having a bear of a time getting the rt rotor to center correctly any ideas guys maybe it was teh 105 degree heat and the rubber mallet that fell off seat and landed on my head. any thoughts would be greatly appreciated. John
    BTW the 750 FD swap is the best single improvement i have done
    79 XS1100SF 750 FD,Galfer Brake lines,ebc brake pads,Cross Drilled Rotors,TKat fork brace,bead blasted wheels repainted and polished
    80 XS1100 S Project gonna be a hot rod
    06 CBR1000RR sold!!!!!
    2000 Concours
    84 Kawi KLR600
    79 Yam XT500 Ouch it kicks back
    79 XR250
    Why is it that the smallest part can fly to the farthest part of the shop?
    John
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    Loosen the axle clamp bolt, on the right fork and move the fork back/forth until it's centered.
    '05 ST1300
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      Dont know if this could contribute but I have had the factory caliper bolts on my special bend ever so slightly right where the threaded part screws into the fork but have never been able to figure out why. Question: When you unscrew the bolt does the caliper move back and forth slightly with the bolt? If it happens it is a bear to get everything working right unless you hit that perfect spot when the bolt lines the caliper up with the rotor. I replaced mine with high grade bolts from the hardware store and have had no problems since.
      Mike Giroir
      79 XS-1100 Special
      • Paintman
        • Mar 2008
        • 312
        • rapid City SD
        Brakes
        Thanks guys my brain was fried from the heat yesterday. tad i put in new grade 8 bolts and i jiggled fork a bit now she is perfect. its amazing how you can look at somethig for an hr walk away and look at it again and say wow how could i ahve missed that. Well time to head to sturgis later and eat some harleys. with teh FD swap its nice to cruise in 4th gear and having a real first gear what a difference.
        John
        2000 Concours
        84 Kawi KLR600
        79 XR250
        John
        • egsols
          • Jan 2006
          • 1090
          • Barrie, Ontario, Canada
          Hardhat or hockey helmet?
          Ernie
