Fifth gear mod
  • #91
    The problem is not cutting the gears, it is case hardening them afterwards
    Acta Non Verba
    • #92
      did any one ever get a quote from the gear specialist, or did that just fall through, I am sure those would be hardened.
      • #93
        I have access to a heat treating oven here at school. I could just get them to throw my machined gears in with one of the first year student projects. They do a few items out of 1018, then carburize and case harden. 2nd year (me) do all our projects out of 4140 and then heat treat. Either way, I could make this work.
        • #94
          1700 at fifty five in LT Z,,OT car gearing
          Hi,
          My Z28 runs at about the above rpm at that speed in sixth, its great. But if you want any substantial passing power, try fifth at that speed. Just goes to show, that there is an end limit to hi road speed gearing. I cant run the z below 45 mph in sixth, and you dont want to have to accelerate hard out of that range at all.
          Originally posted by DavesXS View Post
          3k at 75 is what my Z does in 5th. And thats high for a car. Probably just right for our bikes.
          Edit: maybe more like 3.5k at 75 for our bikes.
          Bikes Now.
          80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
          79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
          83 Yammi Venture with custom footboards, 20k miles.
          83 Yammi Venture parts bike
          99 Valkyrie shield and bags 37k miles like new
          08 ZX 14 Kawa Ninja 6k miles Sold
          • #95
            Read everything, need the clever guys again.
            Calculated 70mph to 112kph. I am running 160kph on 5k. I do 60kph on just above idle (About 1.5k). Highway speed here by us is 120kph, which I do comfortably at about 3K. I don't have the best pull away speed, and doubt if I will be able to lift her in first. Have Lifted her slightly by fast gearing to second coming out of a turn. I have never had the need to down gear except when getting close to a road stop or something. A GPZ600 kills me on pullaway, but as soon as I hit second, I leave them in the dust. My power band does not kick in at 4k. I seem to have two seperate powerbands. 1st one kicks in at about 6, and the second just over 7. From 6 to seven she has torque like you wont believe, and over 7, she picks up speed at an extremely fast pace. It's as if she just gets a second breath when hitting 6k, and past 7k, just lets everything out. Rev's also seems to climb more over 7.
            The mod you guys are discussing sounds like something that has been done on Bones by a PO. I might be stripping the motor this weekend have a few things I need to do and investigate inside the motor. What should I look for to identify what has been done on the gear ratio / final drive etc. While it is open, I can help you guys and tell you what I find in there. Just need to know what to look for.
            '79 XS1100 (2H9) named Bones
            1196 Big Bore
            4-1 Cowley exhaust
            750FD Conversion
            Echlin 54mm Racing Cones (Americanese = pods)
            Black Ebony Bottled glazed Tank (To be redone now)
            BMX footpegs
            Tank internally lined (Professionally this time)
            GSX400 Throttle bodies (Under serious investigation)
            Anti Sticky float bowl system
            • #96
              Athedra,
              The stock XS11 final drive has a ratio of 3.3:1 and the 750/850 FD has a ratio of 2.9:1 so while you are tearing it down, you can check the ratio and know what you have.
              • #97
                I would come closer to saying you have a 750/850 final drive and that your speedo is off.. something these bikes are notorious for... or even your tach. 10mph fast at 90 isn't uncommon at all. Check the speeds again with a GPS if you get a chance. With the 750 final drive, at 5k rpm, my bike is doing right at 90mph (145km) checked with a GPS. My speedo is off the OTHER way though and barely says I'm doing 80mph.
                Although maybe not an impossibilty... it's going to be really doubtfull that some P/O took the time and extreme resources needed to totally redo a transmission gear from scratch to make an overdrive all on their own on a bike before it was a classic.
                • #98
                  Will check the FD when everything is stripped down. Will also do check the speedometer. Will check it next to a car. GPS's is currently still way overpriced over here.
                  Anyway, the lady speaks to slow, by the time she has said "Turn left 500m", I need to make a u-turn.
                  Would be nice to have the FD already done, then I can tick that off on my list of things to do.
                  1196 Big Bore
                  4-1 Cowley exhaust
                  750FD Conversion
                  BMX footpegs
