The problem is not cutting the gears, it is case hardening them afterwards
Fifth gear mod
did any one ever get a quote from the gear specialist, or did that just fall through, I am sure those would be hardened.Comment
I have access to a heat treating oven here at school. I could just get them to throw my machined gears in with one of the first year student projects. They do a few items out of 1018, then carburize and case harden. 2nd year (me) do all our projects out of 4140 and then heat treat. Either way, I could make this work.BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
80 XS1100SG(cafe in progress *slowly)Comment
1700 at fifty five in LT Z,,OT car gearing
Hi,
My Z28 runs at about the above rpm at that speed in sixth, its great. But if you want any substantial passing power, try fifth at that speed. Just goes to show, that there is an end limit to hi road speed gearing. I cant run the z below 45 mph in sixth, and you dont want to have to accelerate hard out of that range at all.
Bikes Now.
80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
83 Yammi Venture with custom footboards, 20k miles.
83 Yammi Venture parts bike
99 Valkyrie shield and bags 37k miles like new
08 ZX 14 Kawa Ninja 6k miles SoldComment
Read everything, need the clever guys again.
Calculated 70mph to 112kph. I am running 160kph on 5k. I do 60kph on just above idle (About 1.5k). Highway speed here by us is 120kph, which I do comfortably at about 3K. I don't have the best pull away speed, and doubt if I will be able to lift her in first. Have Lifted her slightly by fast gearing to second coming out of a turn. I have never had the need to down gear except when getting close to a road stop or something. A GPZ600 kills me on pullaway, but as soon as I hit second, I leave them in the dust. My power band does not kick in at 4k. I seem to have two seperate powerbands. 1st one kicks in at about 6, and the second just over 7. From 6 to seven she has torque like you wont believe, and over 7, she picks up speed at an extremely fast pace. It's as if she just gets a second breath when hitting 6k, and past 7k, just lets everything out. Rev's also seems to climb more over 7.
The mod you guys are discussing sounds like something that has been done on Bones by a PO. I might be stripping the motor this weekend have a few things I need to do and investigate inside the motor. What should I look for to identify what has been done on the gear ratio / final drive etc. While it is open, I can help you guys and tell you what I find in there. Just need to know what to look for.'79 XS1100 (2H9) named Bones
1196 Big Bore
4-1 Cowley exhaust
750FD Conversion
Echlin 54mm Racing Cones (Americanese = pods)
Black Ebony Bottled glazed Tank (To be redone now)
BMX footpegs
Tank internally lined (Professionally this time)
GSX400 Throttle bodies (Under serious investigation)
Anti Sticky float bowl systemComment
Athedra,
The stock XS11 final drive has a ratio of 3.3:1 and the 750/850 FD has a ratio of 2.9:1 so while you are tearing it down, you can check the ratio and know what you have.Life is what happens while your planning everything else!
78 XS750Comment
Although maybe not an impossibilty... it's going to be really doubtfull that some P/O took the time and extreme resources needed to totally redo a transmission gear from scratch to make an overdrive all on their own on a bike before it was a classic.
Will check the FD when everything is stripped down. Will also do check the speedometer. Will check it next to a car. GPS's is currently still way overpriced over here.
Anyway, the lady speaks to slow, by the time she has said "Turn left 500m", I need to make a u-turn.
Would be nice to have the FD already done, then I can tick that off on my list of things to do.'79 XS1100 (2H9) named Bones
1196 Big Bore
4-1 Cowley exhaust
750FD Conversion
BMX footpegs
