Bike starts and runs strong. Problem is that after a few minutes it starts to smoke bad from the left hand exhaust. When I first start it everything is good, no smoke at all. After it runs for a few minutes smoke billows from the left exhaust, Nothing from the right which I find strange. I can shut it down and wait for it to cool off and restart and again no smoke untill it warms up. I had the pipes off for 2 weeks standing on end so I don't think they are full of oil. Although there appears to be some oil collecting at the rear of the pipe. PO tried unsuccesfully to remove the baffles, Just left a big gaping hole on the ends of the mufflers.
A little history may help. I bought it from not running. PO said that it smoked black. No wonder the carbs were full of varnish and dirt. Also when I drained the oil to change it out came 7+ liters of clean oil, NO gas/oil mix, I know what that looks like from previous experiance with an XJ! Oil looked like it was just put in. Imagine my suprise.
Now, so far I have cleaned and reinstalled the carbs, rebuilt the petcocks, changed all the fluids. It seems to be running a little rich although no more black smoke, just blue from the left pipe. It is firing on all 4 and the plugs are not wet with either oil or gas. Just a little black from rich mixture.
Any thoughts? All suggestions will be considered. Thanks in advance for your ideas.
Darrell
Darrell
, a search will reveal lots of info, both in the tech tips, and in the Posting FORUMS.
