Bad Luck
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    Bad Luck
    Sorry just venting.
    Bought a 81 SH with the intent to do some minor work on it and have a ridable bike.
    First problem was the starter not engaging, which I thought was no big deal, but it turns out I have to split the case to fix it. Good thing the repair kit is only about $25.
    So, I figured I should get it running first, and see if getting the engine warmed up and cleaned out would help the starter clutch engage.
    I looked pretty funny trying to pull start a bike with my wife pulling me down the road in our Yukon.
    It wouldn't even fire.
    Started checking things, found the cams out of place. Bent #2 and #3 intake valves. #1 and #4 didn't get bent, strangely. All the exhaust valves are fine.
    I did find some valves for a decent price, which is much better than the $60 a piece for OE parts. Still trying to find a chain for a decent price. $90 for that small chain is ridiculous. I have half a mind to go to Tractor Supply and see if they have metric chain. Its probably right nest to their metric plow bolts. (have to be a farmer to understand that one hehe)
    So, now it looks like closer to $300 -$400 to get it running.
    Still looking forward to the bugs in my teeth. Hope I can get it running before Kansas passes a helmet law.
    Ich habe dich nicht gefragt.
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    for cam chain.
    don't forget to also order the master link.
    http://www.z1enterprises.com/catalog...S1100-1981-EN0
    do a search on this site for "master link"... turns up a few recent threads on cam chain replacement.
    • Ivan
      • Jul 2008
      • 2524
      • Hutchinson KS
      Wow, that is an excellent price.
      Too bad they don't have valves and gasket kits. hehe
      Thanks a bunch, I'd say a million, but would you do with thanks a 70?
      Ivan
      • dbeardslee
        • 4385
        • Maineville, OH
        Ivan - Partsnmore has a pretty complete engine gasket set for $77. I've used it and the quality of the parts is good.
        Prom - What Ivan said - WOW! That's the best price on a cam chain I've seen yet.
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          yeah I was planning on that gasket kit.
          Planning on valves from: http://crc2onlinecatalog.com/Index_Main_Frame.htm
          the chain from Z1 and the rest is all time.
          Anyone know where to find a good price on some extra elbow grease?
          Ivan
            Ivan
            Possibly? Edit your profile to put your city/state location, and also do a search in the MEMBER's LOUNGE, read the STICKY thread, you might find some members closer than you think, and many like to work on these bikes as well as help out fellow riders!? Worth a try!
            • Ivan
              • Jul 2008
              • 2524
              • Hutchinson KS
              Updated the profile.
              The elbow grease was supposed to be tongue in cheek, I am horrible at expression through type.
              I like tinkering on these type things, as long as I don't get paid for it. Wrenching cars for a living was hell for me. Overhauling my bike in the garage is relaxing though.
              • mro
                • 4276
                • Hayward, California
                If splitting the cases would not use a master link.
                mro
                • Ivan
                  • Jul 2008
                  • 2524
                  • Hutchinson KS
                  I already ground off the link from the old chain. It is pretty well worn out.
                  Do new chains come in a continuous loop? I have never worked on bikes before. I am a noob.
                  • dbeardslee
                    • 4385
                    • Maineville, OH
                    Ivan - some do, some don't. The factory chain is continuous. The aftermarket I got from Partsnmore needed a master link. Don't know about the z1 chain.
                      Go back to prometheus578's response. The master link is available.
                      • olebiker
                        • Aug 2007
                        • 692
                        • Kingston ON
                        Re: Bad Luck
                        Sorry just venting.
                        It seems that the number 3 intake hits first as they go out of time. I know this cause I bent it not once but twice. The gasket kit mentioned works great. I didn't know about that chain the one I bought was about 35.00. Be cautious on reassembly as that was when I bent it the second time. The chain ended up beside the bottom sprocket it turned the valves enough to stay in time through two revolutions by hand but as soon as I hit the starter BOOM. Just check very carefully that the chain is on the sprocket.
                        http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                        • Ivan
                          • Jul 2008
                          • 2524
                          • Hutchinson KS
                          I have ben t plenty of valves on car engines from screwing up. FWIW, Saturn engines have the mark on the crank go AWAY from the colored link (DOH!)
                          The neat thing about this bike is that I have the cylinder head off and I can see the position of the pistons while the timing mark is at TDC, so I should be able to see the lobes and be sure it is ok.
                          That being said, I am the king of missing the very small yet vitally important detail. Maybe I should look into being a doctor or aircraft mechanic. :P
