Hi Guys, I recently installed a Kerker 4 into 1 header on my XS11 Special. Lately I ride and come back home and always smell like an exhaust pipe myself!! The thing is, I thought it was coming from where the down pipes go into the collector of the header. I sealed those up but still have the smell. It appears that the header pipes aren't sealing up tight at the engine block even with new exhaust gaskets and really tightening the brackets. I can't double the gaskets cause the studs aren't long enough. Can I use the red high temp gasket sealer to help seal where the pipes meets the gasket? Any advice or comments? Thanks Guys, I appreciate anything you can offer.
