I have been having a problem developing power on my SF after about 5000 rpm. The engine doesn't wanna' rev much past 5500 or 6000 rpm. A few things I have done ...Carbs gone through, sync'd, new plugs, good big spark, plenty o fuel .... compression checked cold (wouldn't run at the time) cyls all even.
Had been having trouble with my timing light so I finally bought another one, and true to form for me today, soon after I began to use it, it also failed. Nice, eh? But it did work long enough to see that, when the pointer and the timing plate are set in the middle of their respective slots, my timing seems to be about 30 degrees advance at idle. It also cranks like an engine that's too far advanced ... a labored first revolution or two, then the cranking speeds up and it fires. In order to get the timing to read 10 degrees at idle, I would have to shift the pointer most of the way in one direction and the timing plate most of the way toward the stops in the direction of the pointer. I realize that shifting the pointer is not setting the timing .
... it almost looks as though I'd have to remove the screws in the advance plate to swing it far enough to get it into time??? I know I can't do this either .... sooooo ..
Could the pick ups be placed wrong? ... does the pointer need to be zeroed ? Something else altogether?? This is makin' me a bit crazy ..... any ideas would be appreciated ....
... it almost looks as though I'd have to remove the screws in the advance plate to swing it far enough to get it into time??? I know I can't do this either .... sooooo ..Could the pick ups be placed wrong? ... does the pointer need to be zeroed ? Something else altogether?? This is makin' me a bit crazy ..... any ideas would be appreciated ....
[/IMG] [IMG]
[/IMG]
