Front Master Cylinder
  • Fddlefoot
    • Nov 2006
    • 71
    • Arvada, CO
    Looks like I may need a new front Master cylinder for a 79xs1100SF any ideas where I maybe able to find one?? Thanks ahead of time for any help.
    " That glass isn't half empty it has a hole in it "
    79 SF set to cruise
    80special work in progress
    and now 78 needs work
  • DavesXS
    • Jun 2008
    • 231
    • Matthews, NC
    Originally posted by JACKHAMMER01
    You can get them here:
    http://www.mikesxs.net/mikesxs-chass...ategory_id=1.2
    Master Cylinder Assembly
    Master Cylinder Assembly - 16mm bore. - Recommended for late dual disc Front
    brakes on 1977-84 XS650โ€™s or single front disc brake (1972-76 650โ€™s). Yamaha
    OEM type. Complete with brake lever, brake light switch, banjo bolt and washers.
    Part #08-0265 $79.00 USD EA.
    Here ya go
    Page 2 on this forum has a leaky front break thread and pics of this installed on mine.
    • jjwaller
      • Oct 2005
      • 242
      • Gautier, MS
      Put the Mikes XS 16 mm MS on my 78E
      last year. Works great!! Highly recommended.
      John
      Now: '78 XS1100E 750 FD Mod (Big Dog)
      '81 CB900C ( 10 Speed)
      '78 CB750F ( The F)
      '76 CB400F ( The Elf)
      New '82 Honda MB5 Ring Ding
      Then: '76 CB550K
      '78 CB750F
      '84 VF1100S
      And still Looking!
      • dbeardslee
        • Nov 2007
        • 4385
        • Maineville, OH
        Fddlefoot - are you sure it isn't rebuildable? The rebuild kits go for about $20 which is much less expensive than the full monty.
        • tomatao
          • 133
          • Red Bluff Cantafordya
          If you have the original buckhorn bars on your SF you may not like the one from Mikes or Parts N More. The resevior is not angled. I bought one for mine before I switched bars. At the angle of the bars the fluid was just barely covering the hole. I ended up rebuilding my orignal one and it worked fine.
          Once I switched to bars that were much less angled the one from Mike's worked great. I like the lower profile, cleaner look of it.
          1979 XS11SF (Shiny Red Sled)
          1982 XJ11 (winter project- Black Beauty)
          1992 XT225 (yard sale find)
          Decide-Commit-Succeed
          • Fddlefoot
            • Nov 2006
            • 71
            • Arvada, CO
            Thanks
            Already rebuilt and is spongier than hell so that looks to be out saw that one on mikes but still have buckhorns and love them so that doesn't sound real promising damn. Anymore ideas
            79 SF set to cruise
            • dbeardslee
              • Nov 2007
              • 4385
              • Maineville, OH
              Spongy is usually a sign of air in the line. Are you sure you bled all the air out when you rebuilt? Also, when your bleeding the master cylinder if you pull the handle too far it can make the little rubber plunger thing come off it's seat. They recommend putting a two-by-four between the brake handle and the grip when bleeding the master cylinder to insure you don't pull it too far. Also, after bleeding the system you may need to add more brake fluid as some air bubbles can migrate up through the hoses. And last, but not least, there are a couple spooge holes under the reservoir that sometimes get plugged.
              • tomatao
                • 133
                How are your brake lines? If you still have the original rubber lines it may be time to upgrade.
