I have to replace a float pin on my bike and was wondering do i have to remove the carbs or can i just run the bike until it out of fuel(by shutting off the petcock) and then remove the float bowl?I really don't feel like removing the carbs again for this simple fix.I know the pin(nail) will come out easily.
float pin
I don't see any reason you shouldn't be able to do it, providing it's either #1 or #4. The internal ones would probably be less trouble to remove than try to service installed. Don't run it out of gas!! Gas is expensive! Shut off the petcocks and drain the carb into something clean and pour it through a paper towel back into the tank.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
drilled stock airbox with K&N
Jardine 4 to 1 Exhaust
spade fusebox
1st and 2nd gear fix
I agree with boyat68.I just worked on my carbs last week and took someone elses advice and removed all 4 pins.I then took four drywall screws(I mic'd em and they are about .003 smaller than the pins) and nipped the pointed end and the heads off and filed the ends smooth.I used those and set the floats right and now I can remove the pins without worrying about breaking a post.So far they run great!80 SG XS1100
14 Victory Cross Country
Decided to do this even though the weather was close to 100 degrees out.Removed float bowl and removed float pin because someone told me that steel pins will rust in gas.I ordered 5 from Bike Bandit and it went in fairly easy.Replaced float bowl and tightened screws.Took it for a test drive and all is good.1980 XS1100 SG
I got a PM from someone on this site that told me it was written in a thread that a steel should not be used as pins because they rust.-i looked and couldn't find it but i guess it could happen.1980 XS1100 SG
that was my info
Hi Old yam,,,that was my message to not use steel nails. The oxygen in the bowl will combine with iron and create iron oxide-aka "rust" and rust in the carbs is not helpful. Unless the pins could be kept out of any contact with the air and the oxygen in the fuel, they will rust quickly. Stainless nails are best,,,,some have used zinc and have been happy. Some have used cotter pins and finish nails and cut off the end to fit and done ok. Any others used anything else to replace the pins?? They are cheap, even from the dealer, like 2.00 each but some have used alternatives......mike in s.d.mike
1982 xj1100 maxim
1981 venture bagger
1999 Kawi Nomad 1500 greenie
1959 wife
maybe I should just file down the fat part of the stock pins so they just slide in.Tim Ripley - Gaithersburg, MD
23mm float height
120 main jets
42.5 pilot jets
spade fusebox
Thank You soccer4m-i knew i wasn't seeing things.Thanks again!The last thing i want to do is take off the carbs.1980 XS1100 SG
