Color XS1100G USA Schematic
  • xs11jack
    HALF GURU
    • Nov 2002
    • 606
    • O'Fallon, Mo.
    One of the
    Best things an Yamahamer owner could want. Bless you my son!!!!!!
    J.D."Jack" Smith
    1980G&S "Halfbreed"
    1978E straight job
    "We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
    Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
    • BobE
      • Mar 2008
      • 102
      • Richmond, RI
      Scott,
      Thank you so much! I am a new owner of an XS1100G, so I reeeeally appreciate this!
      BobE
      Richmond, RI
      1980 XS1100G - "The Old Coot"
      PREVIOUS RIDES
      2005 Venture, 1993 Venture, 1983 Venture
      1978 Gold Wing, 1983 Gold Wing
      1975 CB500T, 1983 Husqvarna 250WR
      1981 XL500, 1975 CB750K5
      1981 CB900F, 1965 C200 (Honda 90)
      1968 Powell Challenger (Hairy-Chested Mini-bike)
        Hey, y'all are more than welcome!
        I got my new bearings and seals installed yesterday - yay! Thank you again, Nemisus!
        Right now I'm making color versions of some of the more common items to print on the back side of the schematic so everything will be on the same page, more or less, and I can roll/fold a copy to keep with the bike.
        Does anyone have any suggestions?
        Regards,
        Scott
          Disco pants? Heated pants with turn signals?
          Originally posted by DJinNH
          It looks like the pattern to a pair of pants I use to have back in the 70's.
          Don
            Heated disco pants with turn signals?
            Hmmm... okay...
            Regards,
            Scott
            • olebiker
              • Aug 2007
              • 692
              • Kingston ON
              She looks I think I mighta well maybe. Hey it was a long time ago. Yes there are gaps.
              http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                Re: Color XS1100G USA Schematic
                Updated with a few Part Numbers and some miscellaneous fixes.
                The full 144K version.
                Enjoy!
                Scott
                  She's held up well and no those new LED blinkers don't make her hips look big!
                  Regards,
                  Scott
                  • Toolmaker Tim
                    • 671
                    • South Bend, Indiana
                    I said it before, but here again, you are an electrical guru. That is NICE!! Thank you. It will go in my notebook of TechTips.( It's starting to get thick!)
                    Good Job,
                    Tim
                    1979XS1100SF
                    K&N's and drilled airbox
                    Jardine 4in1
                    Dunlop Elite 3's
                    JBM slide diaphragms
                    142.5 main jets
                    45 pilot jets
                    T.C.'s fusebox & SOFA
                    750/850 FD mod.
                    XV 920 Needle Mod.
                    Venture Cam Chain Tensioner
                      Thank you, Tim, but I'm no guru by a long shot. The schematic helps a lot in troubleshooting and working on it relieves some stress while waiting for parts.
                      "Where are those parts? The parts should have been here by now. Will the new parts work? Is that the truck?! Where are those parts...."
                      Regards,
                      Scott
                      • Toolmaker Tim
                        • 671
                        Parts
                        I know the feeling. I'm waiting on parts myself. I've been reduced to watching the UPS tracking site for now, great entertainment.
                        1979XS1100SF
                        Jardine 4in1
                        Dunlop Elite 3's
                        142.5 main jets
                        45 pilot jets
                        750/850 FD mod.
                        XV 920 Needle Mod.
                          Bad Regulator/Rectifier
                          I'm having the same fun with FedEx; waiting on a bag-o-parts from Pennsylvania.
                          What started this whole thing has boiled down to an intermittant regulator/rectifier.
                          Every time I'd test it the regulator would show it was okay and charging voltage was right where it was supposed to be. It took a long time to actually catch it doing it, but sometimes the regulator would 'stick' high and overcharge to well over 17 Volts. I've had lots of fun finding and repairing the damage from long-term intermittant overvoltage.
                          After going through this entire process I found out the P.O. had to change the battery a couple of times. Apparently, it would run fine for a while, then suddenly lose water and burn up a battery... I have this sudden urge to open up another burned up factory-sealed component so I can add some more details to the schematic.
                          Regards,
                          Scott
                          • Skin Krawler
                            • Aug 2008
                            • 23
                            • Lemoore, CA
                            Thank you
                            My forward left turn signal don't work. I think I will get to the bottom of it this weekend. Thanks for the schematic!
                            1980 XS11
                            _=-Xcellerator-=_
                            -47,000 miles
                            -rear dropped 1 1/2" w/HD Sporster Shox
                            -HD 12" apes & controls
                            -V*Star seat & bags
                            "You ridin' a Harley, or are you just to see me?"
                            • Shuriken
                              • 1093
                              • Southwest USA
                              Originally posted by 3Phase
                              I had to redraw the entire schematic from scratch with MSPaint to get a clear, printable, image. The one in my
                              spendy factory manual is almost illegible, totally scanless.
                              One of use should do the same thing only using Adobe Illustrator and create a vector image. Then you could resize all you want and the image quality would never suffer.
                              Nice work.
                              Formerly:
                              1982 XS650
                              1980 XS1100g
                              1979 XS1100sf
                              1978 XS1100e donor
                              • rockhoundtx
                                • Dec 2007
                                • 11
                                • Godley, TX
                                Very Nicely Done
                                Very Nice, Well Done and appreciated
                                Rock Hound
                                79' Eleven Special
