wiseco 1197 kit in a 82 xj1100
  • rjs
    • May 2007
    • 2
    • kansas city missouri
    hello, need to know with how much success,has anyone installed an 1197 kit in an xj i have been told that using a xs kit would lower the compression because of the difference in the heads.my source was dynoman who was looking to get every ounce of horsepower for comp tractor pulls if the effect is ill have more horsepower than stock then im interested in the conversion. any advice or personal experience is welcomed including the cheapest place to buy the kit. thanks RJS
  • Bigleo
    • 93
    • Surrey BC Canada
    Hi, I have installed a 1197 kit into a 1980 XS1100. This should have given lower compression, as the 1980 supposedly has bigger combustion chambers. However after the installation, the motor has 165 PSI compression, which works out to 10.25 to 1. Which is as advertised by the Wiseco site. The motor has a lot more power than before.
    Leo
    1980 XS1100 Special
    1197cc Wiseco kit
    1978 cams
    4 into 1 Jardine with glasspack
    Keihin CR33 mm carbs
    K&N individual pod filters
    TKAT fork brace
      Yes, the Wiseco pistons are slightly less domed than the stock XJ pistons, but you are taking nearly 25cc's per cylinder and cramming that into basically the same area as before.
      So yes, it will increase your compression... just maybe not QUITE as much as the 78-79 models, and yes, it will improve your HP.
      • Bamper
        • 97
        • Maine
        So you are saying your friend has a 1197 motor in a tractor
        1979 XS1100 SF (production number 572)
        1972 Kawasaki g4 TR-B with high and low transmision
        1974 kawasaki G4
        2003 Polaris 250 Trailblazer
        1975 Yamaha Enduro 175
        • rjs
          • May 2007
          • 2
          1197 kit in a xj
          thanks for the input,i needed a first hand account before i installed the kit. in reference to the pulling tractor, dynoman is a website that sells wiseco kits i talked to the general manager buzz who laid some very specific info on me about how they built a xj motor back in the 80s for a guy who did competition pulling this motor ran at 10,000 rpms custom made pistons and valves i dont remember all the specifics but he sent me pictures it was pretty cool. he said they tried the wiseco pistons and put it on a dyno but could not achieve the horsepower that they later did with the custom made pistons. the tractor was unbeatable that year . rjs
            If you're looking for more... read the stuff from Dan Hodges on here... Here's a link to one of them.
            BIG bore...
