Fairing removal - wiring help
+ More Options
Posts
  • Beav068
    • 36
    • Salem, Oregon
    Okay, so I just removed the fairing from my '80G and it doesn't look too bad. There are 5 wires that need connected, and I'm not sure what they are.
    I have a blue and a purple on each side (wire bundle), an extra blue, and a red. The red has 12v constant, and I cannot figure out where that would go. The blues appear to be flashers, as the power fluctuates when using turn signal switch.
    When I use the blues as positive and the purples as ground, the blinkers ALL work with the emergency flashers activated, but they do not blink using the regular signal switch.
    The wiring diagrams I have show green and black to the front signals, but I have NO green OR black wires that aren't part of the factory gang plugs (white plasting square plugs).
    Anyone have any ideas? Everything works except for the turn signals.
    Tim
  • Geezer
    • May 2003
    • 2985
    • Willamina, Oregon 97229
    If you can't figure it out, you can ride it up here to Portland and I'll have a look at it.
    Geezer
    • Yahman
      • Mar 2008
      • 779
      • Salem, OR
      The diagram that I have shows Blue wires for the park lights, a Brown wire for the Right turn signal and a Green wire for the Left turn signal. There should be some Black wires from each of the signal units for a ground. I believe the Red wire is an unused accessory wire.
      Hope this helps you.
      Larry
      82 XJ1100
      80 XS1100G (Project bike)
      64 Yamaha YA-6
      77 Suzuki TS-185
      • Beav068
        • 36
        • Salem, Oregon
        Thanks for the replies, guys. I'll see what I can manage with the diagram and my multimeter.
        Tim
