The headlight adjuster on my Vetter vibrates at around 2100 rpm +/- 200 rpm. It can get very annoying and I've try a couple of things to make it stop. They haven't worked.
Has anyone else run into this and if so, have you been able to fix it?
Maybe I'll take a piece of air hose and slit it lengthways to fit under the knob. (Haven't figured out how to take the knob off yet.) I've been trying from the inside with rubber washers between the spring and the fairing, to no avail.
