Another carb thread
  • DavesXS
    • Jun 2008
    • 231
    • Matthews, NC
    I would have thought there is an air leak. But an equal leak between 3,4 sounds odd too. I can spritz cleaner at the filter and I do mean spritz(psshht) thats it. And the idle will increase. But I can soak the boots, and vac caps and get no change at all. If there was enough air sucking to change the mixture that much I'd get a definate change.
    If I remember correctly the idle screws on 3,4 were set further out before I messed with it and changed any jets.
    I resynced the carbs and now 1,2 are 3.5 turns out, and 3,4 are 4.75 turns out.
    They were 3 and 5.5.
    • DavesXS
      • Jun 2008
      • 231
      • Matthews, NC
      Here is the new clip. The camera speed won't allow you to see the sync. But there all hittin just above -15. If you listen to the first clip and then the second you might here the difference when I first twist the throttle off idle.
      Also for any one wondering, I took a close up of how I ran fuel lines. Ran the 2 returns to a T and up to a filter, and to the petcock, and ran the 2 supplys to a Y and up to same petcock.
      • AlanB
        • Oct 2006
        • 705
        • Scotland
        HI Dave,
        If your needles are swinging as much as it looks in the video, you really need some dampers in the lines.
        Fuel lines are interesting; seems to work, but the XS does NOT have any returns........ only two feeds; one to each pair of carbs.
        There should be no need for four connections to the carbs..... Where do they all go to??
        AlanB
        If it ain't broke, modify it!
        • DavesXS
          • Jun 2008
          • 231
          • Matthews, NC
          Originally posted by AlanB
          HI Dave,
          AlanB
          There are 2 petcocks, 2 ports on each petcock. 4 lines total.
          I do need some dampeners or something. I am sure its close, but not perfect because of the dancing needles.
            • 2117
            That is a good video.
            • dbeardslee
              • 4385
              • Maineville, OH
              Dave - Ace Hardware sells some little valves that work great for dampers. You'll find them in the small plumbing parts. I've also been told that aquariums use a similar device, so if you have an aquarium supply near you they may have a damping valve. The other thing that works is a cable tie. Like a little tiny muffler clamp. Just put one over each hose up close to the guage and slowly hand tighten the bolts 'till the needles just stop dancing.
              • petejw
                • 2269
                • sydney australia
                Hi Dave,
                how r the hose clamps on the intake boots,
                mine were leaking from there, i wrapped electrical tape
                around the boots to thicken em up a bit.
                hope u fixed ur off idle stumble.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • egsols
                  • Jan 2006
                  • 1090
                  • Barrie, Ontario, Canada
                  Dampers
                  I used small c clamps (1.99 each). Worked great.
                  Ernie
                  • DavesXS
                    • Jun 2008
                    • 231
                    • Matthews, NC
                    Thanks guys. Your suggestions for dampeners gave me an idea. In turbo charged cars a generic way of increasing boost is to put .035 weld tips in the line to the waist gate.
                    That should work for dampeners.
                    I'll try that and re-check the balance. Took a ride today and it still isn't right. Just better than it was. Gonna have to get colortune to.
                    And I'll be wraping some elect tape around the boot ends just in case there not tightening 100%, Then buying new boots soon as I can.
                    • DavesXS
                      • Jun 2008
                      • 231
                      • Matthews, NC
                      Update
                      I finally got rid of the off idle boggy thing.
                      Once I set all the floats dead on 23mm its great. All 4 idle screws are the same now. 3.25 turns out. No need to open one 2-3 turns more. I have colortune on the way for the final tune once the iggy is finished.
                      I had to do it twice. The first time one was 1mm low and I had to adjust a idle screw further then the rest. Using the carb cleaner spritzed into the filters worked well to get the mixture set. Run them all in untill a spritz makes all 4 increase idle when spritzed. Then turn the idle screws out 1/2 turn at a time untill a spritz cause it to bog down. You've just reached the breaking point at too rich. Now back idle screws 1/4 turn. Thats close to where it should be. I am interested what color it will be from this method.
