Tach Help!!
  • geniusloerts
    • Jul 2007
    • 420
    • fayetteville, Arkansas
    sounds good......
    I ordered the dash indicators too so that i can see my signals, low fuel, neutral and low oil pressure...... might as well was only $36 more
    1979 XS1100 SF "Black Goblin"
    -Pod Filters
    -4-1 pipe
    -larger jets for carbs
    1982 XJ1100 "Black Sheep"
    • danteinien
      • Mar 2008
      • 101
      • Utah
      Yeah, I was thinking the same thing...
      Looks like I have it set to 2, and its reading perfect. Hopefully you'll get the same results
      • Yahman
        • Mar 2008
        • 779
        • Salem, OR
        geniusloerts and danteinien
        Lets see some photos of these Vapor tachs installed.
        Larry
        82 XJ1100
        80 XS1100G (Project bike)
        64 Yamaha YA-6
        77 Suzuki TS-185
        • geniusloerts
          • Jul 2007
          • 420
          i will have pics up in a minute when they finish uploading
          so i hooked it to that wire and i get the following "----"
          i will mess with it more.
          -Pod Filters
          -4-1 pipe
          • geniusloerts
            • Jul 2007
            • 420
            i want to get a lower profile headlight
            -Pod Filters
            -4-1 pipe
            • cloerts
              • Mar 2007
              • 153
              • Tahlequah, OK
              old guages
              did you install your old guages on my bike yet?
              Casey
              1980 xs1100g "Frankenstein" (Now with a mind of his own!)
              "What do you mean I can't park this thing here?"
              "Shiny side up? I don't have a shiny side."
              • danteinien
                • Mar 2008
                • 101
                • Utah
                Did you make sure to expose the copper wire first on the red wire? And make sure that it's contacting the metal inside where the black one goes in?
                • geniusloerts
                  • Jul 2007
                  • 420
                  yeah i did that........ but i will pull it off and double check it to be sure it didnt slip off.
                  cloerts,
                  I think your cable is busted in the tube going down to the wheel, that is why it bounces like crazy. if we are lucky we could pull the old internals out of mine and slip it into yours and it would be fixed.....since i dont use that cable anymore.
                  BTW.... i got your bike to go pretty quick...hehehe walked right away from the KZ...all i know is that the speedo was pegged and bouncing...haha. i asked jason how fast we were going and he said he wasent sure but we were waaay past the last known mark on the KZ.....85.
                  I will put the 140 speedo on it after work today.
                  -Pod Filters
                  -4-1 pipe
                    Missing bolt?
                    geniusloerts, it looks like you're missing a bolt on the steering stem.
                    Is it just an old picture?
                    Regards,
                    Scott
                    • geniusloerts
                      • Jul 2007
                      • 420
                      3Phase,
                      are you talking about the one that holds the upper tree?
                      I took those last night.
                      -Pod Filters
                      -4-1 pipe
                        3Phase,
                        Yes, there is supposed to be a bolt going through that open hole shown in your picture underneath
                        the large chromed bolt on the top of the triple tree.
                        Regards,
                        Scott
                        • geniusloerts
                          • Jul 2007
                          • 420
                          If i remember right there is one there, it is a allen head and it is black, but i will check it out when i get home
                          -Pod Filters
                          -4-1 pipe
                            Sorry, this is what I have.
                            Regards,
                            Scott
                            • geniusloerts
                              • Jul 2007
                              • 420
                              still no tach signal....... i need to mess some more.....i am not surprised tho because when i got the bike it had all kinds of wiring problems with the lights.....so no surprise here either...
                              danteinien,
                              where did you ground the tach sensor wire?
                              -Pod Filters
                              -4-1 pipe
                                Have you tried hooking it up to the stock white tach wire from the stator? If the new tach can't handle the AC signal from the stator, a inexpensive diode will rectify it to pulsed DC.
                                If the tach won't work or stops working: the charging system is on the fritz; you used a diode that was just a tad too inexpensive; the tach is bad.
                                Regards,
                                Scott
