Vacuum Diaphram assembly
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    Re: Vacuum Diaphram assembly
    Originally posted by FANNING507
    I have overflow problems with #2 carb. I will bend the tang to put more pressure on the needle. Does anyone have a diagram of how the vaccum diaphram is to be assembled? I replaced the flexible diaphram, but fuel is leaking past the control. I think that it was assembled wrong before I got to it, and I replaced it as I found it. There isn't many pieces, but the repair manuel doesn't show the assembly. Kim
    Bending the float height tab or tang as you call it will not increase the pressure applied to the float valve. It will only change the fuel level in the bowl and set off a new issue.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • FANNING507
      • Jul 2008
      • 103
      • south central Kansas, Turon
      vacuum diaphram and second problem
      Appreciate the advice. I will thoroughly clean and retry. Thank you very much! Kim
      '81 XS11 LH (MNS)
      "On a scale of 1 to 10, I have an eleven!"
      "Excess is easier to say than XS,"
