where is carb, emulsion tubes, part
  • soccer4m
    • 694
    Hi carb gurus, I am rebuilding the carbs on an 80 midnite and have all the parts in and mostly cleaned but cannot locate these emulsion tubes, part d in the pic,,,,where are they so I can clean them???. thanks for those that can lead me to sanity....Mike in san diego. This is the bike the test pilot dummy rode to the Yosemite rally, it runs but a little rough so it was time for the carb go through.
    0830-carbjets.jpg[/IMG]
    mike
    1982 xj1100 maxim
    1981 venture bagger
    1999 Kawi Nomad 1500 greenie
    1959 wife
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    The main jet threads into the bottom of the tube which must be withdrawn through the top of the carb after the CV slides have been removed.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • newc4
      • 596
      • Vienna VA
      As Rob said the main jet screws (looks like Part B) into the bottom of the emulsion tube. You need to remove the top of the carb and the CV slide. Flip it upside down. After I remove the main jet, I use a small socket to tap the tube out Be sure you don't shear off the brass pin that aligns the emulsion tube, that's what the notch in the lower end is for. I then dip in carb cleaner for a bit the clean it up with Qtips and needles to ensure all the emulsion ports are open.
      Darrell
      Darrell
      78E
      80G project
      06FJR
      • soccer4m
        • 694
        thanks
        Thanks guys I will try that in the daylight tomorrow. I did everything else but clean those emulsion tubes,,,,,ride on, Mike in S.Diego
        mike
        1982 xj1100 maxim
        1981 venture bagger
        1959 wife
